DTP can be checked with a DMM by applying one probe to the little protrusion on either side in the center, the little overflow tabs, where the thermal pad is. Use continuity to see if it grounds out, say on one of those screws, then you’ll know if there’s mask between that pad and the copper star.
Thanks for the effort. I loved the strip down.
thanks for your answers!
DTP will be checked net time I open the light.
(that simple idea did not came into my head)
@lumen increase :
is that the way vinh does the driver?
I saw he also ads heatsink…
what could be expected from a R100?
vinh level or on the saver side?
nice light i wonder when the next GroupBuy for this light will begin.
Does anyone know if removing the pickup sensor for strobe would cause any more parasitic drain with the ring in the strobe location than it would in the standby location?
Nice teardown info and pictures. Thank you M4D M4X.
the original K40 didn’t have this brass retaining ring
R082 resistors at the upper right. modding time thanks for the pix!!!
first i managed to rescue Mode 2
not best soldering - but thea are sooo tiiny!
then i opened the light again to ad a R100 to the sense Resistors:
L1 | 0,024 | 0,029 | +20% |
L2 | 0,83 | 0,95 | +15% |
L3 | 8,6 | 11,36 | +32% |
L4 | 21,8 | 28,1 | +29% |
L5 | 37,2 | 46,3 | +24% |
L6 | 60,1 | 73,2 | +22% |
kLux measured at 107 cm with HS1010A
The light gets hot very fast at L6
Lux drop to 69 kLux @30 sec
Sir m4d m4x, how do you turn the brass retaining ring in the tail cap? Clockwise or counter clockwise… im trying to open it but no success. Its too hard to open… tia
I tried opening the tail cap again but i cannot open it at all…the retaining ring is kinda stuck… so it means i cannot replace the tail cap… i emailed acebeam but the reply only says to have it check to whom i bought it… i thought acebeam support international warranty
I will check for the brass ring of the Reflector tonight…
which ring in the tailcap?
why do you open that?
Yes sir… ring in the tail cap… to access sa tail cap boots…
I just trying to open it i know if the tail cap boot are replaceable… but i cannot open it….
that silver ring opens counterclockwise…
I tried your technique using a needle nose pliers but still no success…. its too hard to turn it… i thinking that it is kinda stuck…
Nice teardown with good pictures, enjoyed that :-)
That is not a silver ring… it is a brass ring… the 4th picture you posted…
Just turn harder, often the aluminium threads when they aren’t lubricated grab onto the brass retaining rings. I had to pull a brass pill out of an aluminium host the other day and it needed two people to do it. One holding the body with a rubber gripping cloth and one with the circlip pliers with a bar going through the handle for leverage. Once it came out it was fine, but there was no lubricant, no threadlocker etc, it was just really tight and had stuck in there.
Are you sure sir? Because i tried it both ways but no luck of opening it….
I stopped trying to open it because im damaging the ring
I dont want to try it harder cause im damaging the ring itself….
