Sweet mod! I’m jealous now!
nice mod ,great thrower.
Vinh HAS to do a run of these with the XPG2, what a fantastic mod, well done
wow, amazing mod kenjii, maybe i will send you mine, hehe
Nice work. That final beam shot picture is cool.
You mean like this?
I already have a second one for our man in Amsterdam (not djozz). But this time i am going to take the most powerful one. When modding the Thrunite Catapult he got the better one.
Greetings
Kenjii
Does the head twist or slide?
Great work, I always like seeing the red threw aspheric’s.
I absolutely love the look of that light in shorty mode. Next time use the FET driver in it.
Twist. And very smooth, too.
Hi Kenjii, I did a similar mod on the Uniquefire UF-1406 (here) and I am curious about how they compare. Are you able to measure the output (in lumens) of the modded Jax at zoom-in and zoom-out?
Hy,
no unfortuantly i can´t measure lumens. Never did ceiling bounce, too. I am only interested in Lux/candles
Yes, i saw the Z1vn but i don´t think they will be comparable to mine as Vinh uses a single cell driver, so it will be almost impossible to reach stable high currents. MT-G2 and SBT-70 are nice but i think they might produce too much heat for this host.
Greetings
Kenjii
Hy,
the second Z1 for our man in Amsterdam is finished. Both lights perform almost identically. Measured 225-228 KLux/Kcd.
Greetings
Kenjii
Beamshot slightly overexposed due to foggy weather
cool beam shot and great work.
Wow, love that last pic
Hi, er, when taking the Z1 apart, did you have any trouble getting the pill out?
I’m trying to unscrew the pill, or unscrew the black retaining plate at least, and it gets really stuck after about one turn. I managed to bend my tools trying to get it to turn farther.
At a guess, it looks like the black plate might be glued onto the pill or star, and might perhaps have different threading than the pill. So, they turn in sync. It turns easily at first, but rapidly gets difficult and stuck.
So, I’m looking for advice on getting past that, to get the pill out.
Hy,
i had no problems taking out both parts. There was no connection between pill and black plate. I could unscrew the black plate by pressing it with two fingers. Threads are surely different but as i said there shouldn´t be a connection between pill and plate. Perhaps the centerring ring on the LED is stuck at the plate?
Regards
Kenjii
It’s too bad I ordered this just a few days before the host version was released.
It seems like the pill, star, and black plate are pretty solidly glued together. I’m hoping I can let it sit in the maximum-unscrewed state for a while to stretch the glue, unscrew it a little more, stretch, unscrew a little more, etc… and eventually get the pill out. With any luck, doing this will actually stretch the glue instead of compressing it…
I had heard that the MCPCB was glued on with something pretty strong, but I wasn’t expecting the black plate to be stuck too. Glue is a lot easier to deal with after the pill is out.
Hy,
my Z1 is now running with the LED4Power LD-1 5A Driver and an Efest Purple 26650. Short, strong, good runtime Measured at 212 KLux@1m/Kcd.
Greetings
Kenjii
