287 lumen on an Efest 10440 IMR is what you usually get with these drivers: when they do not have to boost, it goes direct drive (with lower modes by PWM) and if the resistances in the electrical path from battery to emitter are not too bad the output gets towards 300 lumen. The cheap Ultrafire M5 does 300 lumens as well on the 10440 IMR (but is just 1 mode).
I did not know that I would get the updated version, that was nice, but what I liked about the old version is that the low mode was current-controlled with no PWM.
That is a pity. (I like to think it has something to do with this review of course, finally gives me the idea that I have an influence somewhere in the world, if only the stock supply of Banggood )
Thanks for the post sir!! I don’t think there are many reviews on it, I’ve being thinking about it for a real good while but the conflicting info were confusing me quite a bit. Some sites displayed it as a 3 mode but I was only aware of the older 2 mode version. I’m glad to see the improvements made, just wished the PWM was kept out and the firefly was kept in this version.
I don't know if this is the same one, but BG still seems to have this in stock got $17.89:
Tool M is a m mini tape trailer strong magnet 's keychain type tools flashlight , suitable for daily use carry . It has weight light , highlight high brightness , bright low endurance long balancedness .
Specification:
Product name:
Lumintop Tool M Cree XP-G R5 LED Flashlight
Brand:
Lumintop
Emitter Brand/Type:
CREE
Emitter BIN:
XP-G R5
Material:
Aircraft grade aluminum alloy
Mode:
Two modes:
High:70 Lumens,1h
Low:1.5Lumens,60h
Battery Configurations:
1 x AAA(not included)
Working voltage:
0.9V--1.5V
Switch Type:
Clicky
Switch Location:
Tail of the flashlight
Range:
47 meters
Waterproof:
IPX-8
Weight:
14g
Color:
Black
Size:
76.6mm(Length) x14.3mm(Dia)
Operation mode : will battery anodal headwaiters , enclosable battery , tighten the tube body . tighten the head , amplifys flashlight . unscrewed head , closed flashlight . unscrewed quick and tighten the head , in the low light and mode switching highlight the . default low bright , without memory . flashlight don't anti reverse polarity , please don't fitted reversely battery .
Package included: 1 x Lumintop Tool M Cree XP-G R5 LED Flashlight 2 x Spare O-ring 1 x Packaging
Thanks for the suggestions gentlemen! The one from HKEquipment is not the older version. I was about to buy it, but wanted some confirmation, so I sent a e-mail to them and as far as I understood the Lumintop Tool they have is the newer 3 mode version.
ohaya
I’ll try the e-bay store you suggested, I’ll report back.
The page said XP-G R5 when i bought the light from the OP, but still it was XP-G2. It would be sneeky of BG if they subsequently would sell an old batch.
I PM’d Neal. The special he advertised on our BLF today with coupon code is for the older 2 mode version. From Selfbuilts review on it, it can be used as a clicky, or a twisty from the head or tailcap Also, another user said if u do half presses on the clicky you can toggle the modes! Hoo-Yah!
IMO that is sneaky, he did not say that and it is a relevant thing with a new version available and already sold by BG! The new version has XP-G2, more output and a nice AR-coating on the lens, I think it is the better one. The only thing that is nicer about the old one is that it does not seem to use PWM on the low mode.
