Pardon my ignorance, but I don’t see a specification for this driver, just list of changes in the first post, but not the total spec, features, etc… is it out there somewhere?
The firmware is totally different between the two switch types, they are not interchangeable. To work with a momentary switch it must have been flashed by somebody with the momentary switch firmware.
It's a homebrew deal. Combination of the best parts of the Nanjg 105C (easy to reflash, lots of firmware versions available, parts very easy to get) and the best parts of the East-092 (direct drive with a super-low-resistance FET).
I'm with you vex! I'd love to make these drivers but I'm afraid to dive into the many pages of history to find out which resistor goes where and why and which resisors have become obsolete, so which pads are to be ignored in which board versions, etc. And I was even around following the whole story! TomE started this thread to solve this (thanks Tom), but still it has not become really straightforward for us 'electronically challenged' folks.
About your questions:
-it is a direct driver so the current in your flashlight has nothing to do with the driver, the current is a result of battery, led and various resistances in the flashlight. The only thing the driver does is switching on and off, to introduce pwm to get lower modes and when using an electronic switch to switch the flashlight on and off.
-I am curious about the current best FET as well, since the great Vishay FET has gone out of production.
-the zener diode is used in a 2xli-ion (8.4V) set-up to reduce the voltage for the MCU that can not handle more than 5.5V, e.g. a MT-G2 on a copper board performs great direct drive on two cells.
so which FET should be used then if the vishay is out production?
yep, there are fantastic projects on this forum, really fantastic open projects but they lack just 1% more effort, to keep all features and instructions on one place, i.e. in the first post, such as
features
specifications
known issues
bill of material
assembly instructions
known issues/bugs
changes list / release notes
credits
3rd party sw/hw used
I work in a corporation so we are drilled from day one to pay attention to keeping documentation in shape. I’m very motivated to do stuff but the info is scattered around, and it’s quite inefficient having to go through all the posts in a thread to gather all necessary info.
Yes, the problem is of course that this is all hobby, we're doing it for fun, and however useful it is, maintaining documentation is a pretty boring thing to do...
Absolutely, the info is free and it’s all for fun so there’s little incentive to maintain the first post with needed info, i’m just saying: for newbies on this forum it can be frustrating the amount of info/posts you need to chew through to get the info you need about a project. Of course when you’re a veteran you already know everything there is to know and you probably don’t even notice the missing info.
I use my own e-switch firmware, based on JohnnyC's and can choose what MCU pin I want the switch on - choices are pin #2, #3, or #5 I believe (see code below). Mine by default is on MCU pin #2 and I believe this is typical, most common. Since the BLF17DD has to be flashed with firmware, the pin definition is defined by that firmware, not the hardware. Looked through my pics and found this one with a BLF17DD built in a Convoy L4, and it clearly shows the e-switch wire on MCU pin #2. comfy is correct in post #74:
Here's part of the code header definitions in my e-switch driver. I added more comments than what was there originally. I'm a consulting software engineer with 35 years experience in software development, so know how important it is to have good doc and reference material. but also know there can be too much, redundancy can be a bad thing, and attempting to document things you really don't understand can be worse than no documenting. Sorry for the poor formatting in html:
// Used for FET based Phase Corrected PWM:
#define MODES 0,2,25,255 // 4 modes %: 1-10-100 (for Cheng - no strobe)
#define LONG_PRESS_DUR 21 // How long until a press is a long press (32 is ~0.5 sec), 21 = 0.336 secs
#define PWM_OPTION 0x21 // 0x21 for phase corrected (9.4 kHz) or 0x23 for fast-PWM (18 kHz)
// ----- One-Click Turn OFF option --------------------------------------------
#define IDLE_LOCK // Comment out to disable
#define IDLE_TIME 75 // make the time-out 1.2 seconds
// ----- Turbo Settings -------------------------------------------------------
//#define TURBO // Comment out to disable - full output, step downs after n number of secs
// If turbo is enabled, it will be where 255 is listed in the modes above
//#define TURBO_TIMEOUT 5625 // time before dropping down (16 msecs per, 5625=90 secs)
// ----- Voltage Monitoring Settings ------------------------------------------
#define VOLTAGE_MON // Comment out to disable - ramp down and eventual shutoff when battery is low
#define ADC_LOW 130 // When do we start ramping (3.1v), 5 per 0.1v
#define ADC_CRIT 115 // When do we shut the light off (2.80v)
#define ADC_DELAY 188 // Delay in ticks between low-bat rampdowns (188 ~= 3s)
There's things bout the DigiKey shopping cart feature I don't understand - when I click on the link I have in the OP from July 12th, it clearly has a FET in it. It's very simple to follow the link, then click on the part and get all the specs DigiKey has on it - it's far more complete and detailed than I could ever document myself. It would be a waste to redundantly attempt to produce detailed specs on all parts here - DigiKey and the manufacturer's spec sheets are far more comprehensive - I totally disagree with any suggestion to list part specs here. Also I'm no EE so really can't cherry pick out the most important specs of each part. When I started to build these custom boards, my problem was first, the parts list, second - figuring out where to place the parts, so for these two major issues I think (thought) this OP addressed that. I'm totally open though to suggestions, but getting into general part specs and specifics on firmware seems beyond scope here, maybe it shouldn't be. I know somewhere there is a thread/google doc of a listing of all shared/public firmware drivers and mine is in that list - forgot where, but I should add that link to the OP -- if I can find it . From there, there should be a ref doc/spec on each of those versions. I try to document my stuff in the header/beginning of the driver code - others do this as well, but I'm sure could be done better.
Unfortunately, changes have been moving along fast that I can't keep up with. New versions of these boards have been appearing, maybe being untested/tested, but certainly faster than I can buy/receive/build up/document here. The variations are endless as well.
Important: Just so you understand, the BLF17DD driver used in the above pics is no longer available - it's obsolete. The new one identified as V1.0 on the board, I do have but have not built one up yet and tested, so can't update the pictures yet.
Thinking of adding a section in the OP called "History/Background" where I attempt to doc how and why these boards came about. The "OSHPark Projects" thread doesn't attempt to address it. The thread that really started all of this was created by comfy - I know it's big and long and packed with lots of useful info, but not summarized well anywhere I know of.
Think I found the driver list/repository: Link for all known shared firmware versions: https://www.dropbox.com/sh/yjq5ahllbuqf1zh/0ZaizdmY-E (not sure how updated this is), but just looked at it and there's a wealth of reference material, not just firmware...
There's also the problem of loads of people outside the US who do not have cheap access to Digikey or a similar supplier.
How about one sample build in the OP for a 17mm BLF-fet driver using just nanjg105C (qlite) components, a correct Oshpark board for that, and a FET available through ebay? I could make that sample but I do not have all the right components in house for it now.
Umm, think with the current V1.0 board, the parts match the Nanjg 105C (maybe?) - earlier versions did not match exactly (1 extra resistor I think?), and the eBay FET - do you have a link? I got my own stock of original FET's comfy first found - think still the best. I can no way do FET research - OMG: the amount of time and effort comfy spent on that is just incredible, and I'm incredibly grateful he did!
To me, the important thing of the DigiKey cart list is very specific details on the parts, including full DigiKey accessed specs. This can be used to get the same matching parts elsewhere. eBay sources come and go all too quickly - my only problem with linking them, and again, I'm not an EE and don't know enough to say for sure what parts can be replaced with something close or equivalent.
This is a very DIY thing, if you want to source the parts yourself and assemble it and flash it yourself. It takes some outside research or prior knowledge to figure out what substitutions can be made (like, if you can't find a X7R 16v capacitor, should you look for a X5R 16v or a X7R 10v?).
This is a direct drive driver. It's job is to connect the cell/cells direct to the LED/LEDs as efficiently as possible, there is no regulation or limiting or anything else of any kind. You can use combos other than one cell/one LED, as long as the LEDs can survive being connected direct to your power source with no driver inbetween... 3 XML2s in series with 3 series 18650s, 1 MTG2 with 2 series cells, etc. Higher input voltages will require a Zener diode to limit voltage supplied to the MCU to 6v or less.
Here's the current parts list for the most recent board revision: http://www.digikey.com/short/dq403 Even if you do not live someplace where shipping from Digikey is reasonable, USE THAT LIST to get the part numbers and/or specs of parts used!
The board: https://oshpark.com/shared_projects/IHvO85FY
Capacitor on this latest version has been relocated from the original Nanjg spot between pin 8 & ground, to between B+ & ground. Same parts used, the pads just connect to somewhere different. (This is because with the 'hard' load the MCU's PWM pin has to drive (the big beefy FET instead of dinky little 7135s) the original Nanjg layout of capacitor & diode created a boost circuit, and MCU input voltage would rise above the shutdown point and create unreliable mode changing. The old gate resistor was a clumsy patch that eased the load and reduced (but did not eliminate) the voltage boosting. The cap relocation totally eliminated it, and the MCU now runs at battery voltage (minus the drop through the diode), as it should. If you'd like to see the investigation that discovered this, click here: https://budgetlightforum.com/t/-/27485)
FET - N-channel MOSFET, logic-level gate, gate threshold as low as possible (most will be around or just under 1v), 'total gate charge' (Qg) less than 40nC, lowest possible Rds(on)at 4.5v
D1 - SOD-323 Schottky diode
C1 - 0805 ceramic capacitor, 10uF 16V 10% X7R
R1 - 0805 resistor, 19.1K 1%
R2 - 0805 resistor, 4.7K 1% (tip: the 4.7K resistor is the one that connects to ground on one end; the 19.1K is the one that does not have one end connected to ground)
'2', '3', '4' - these numbers correspond to the 'stars' from the original Nanjg board, NOT the MCU pins. For instance, 'star 4' is on MCU pin 2, and the official name for pin 2 is 'PB3'. Confused yet?
'A' - bridge the two pads to ground pin 2 when using some firmwares; install 1uF 0805 ceramic cap if using an off-time firmware; if using momentary firmware, connect one side of your switch to the inner pad.
'B' - return feed from the 19.1K/4.7K voltage divider
'C' - power feed to the MCU, from the polarity protection diode
Anybody have an idea how much more is this efficient with one FET comparing to using a few 7135 ?
edit: oh and it seems that 7135 is a linear driver, not a FET? Than it is going to burn the excess voltage as heat, that can be calculated then.
But with the FET the current&brightness will diminish as the voltage is lowered during discharge, right?
What is the typical FET voltage drop, to calculate the losses.
Both designs are current limiting, not current regulating and use PWM's for anything other than 100% Hi. They don't have any buck or boost that would lose voltage or current. Both are efficient, but I think the FET design would be considered more efficient because it's about direct drive as you can get. PWM based modes spike max current though, so if your FET based driver gets 5A on hi and a 7135 driver gets 3A hi, a 50% PWM mode on the 7135 based driver will be better than a 30% PWM mod on the FET based, because though they both are using about 1.5A, the 3A spikes will be more efifcient than the 5A spikes because the CREE LED's are more efifcient at lower amps. In implementation, not sure if the difference will be very significant, but it will be there.
Most of us want it both ways: super high turbo mode, but at least a couple of lower levels for more practical close-in uses. Any PWM based driver is less efficient at low modes, and even less efficient if it's max amps is higher.
