very informative post comfychair. I thank you as a flashnoob.
Thanx confy! When I get a chance and get a V1.0 assembled, I'll update the OP with this info from your post.
Anybody have an idea how much more is this efficient with one FET comparing to using a few 7135 ?
edit: oh and it seems that 7135 is a linear driver, not a FET? Than it is going to burn the excess voltage as heat, that can be calculated then.
But with the FET the current&brightness will diminish as the voltage is lowered during discharge, right?
What is the typical FET voltage drop, to calculate the losses.
Both designs are current limiting, not current regulating and use PWM's for anything other than 100% Hi. They don't have any buck or boost that would lose voltage or current. Both are efficient, but I think the FET design would be considered more efficient because it's about direct drive as you can get. PWM based modes spike max current though, so if your FET based driver gets 5A on hi and a 7135 driver gets 3A hi, a 50% PWM mode on the 7135 based driver will be better than a 30% PWM mod on the FET based, because though they both are using about 1.5A, the 3A spikes will be more efifcient than the 5A spikes because the CREE LED's are more efifcient at lower amps. In implementation, not sure if the difference will be very significant, but it will be there.
Most of us want it both ways: super high turbo mode, but at least a couple of lower levels for more practical close-in uses. Any PWM based driver is less efficient at low modes, and even less efficient if it's max amps is higher.
That is wrong, a 7135 will regulate current.
The fet will be around 0.01 ohm resistance.
so what’s more efficient
1. strong FET requiring low PWM which is spiking current and driving LED in the inefficient work regime
or
2. weaker FET/7135 which is limiting current ?
Should a man (or a woman, child, or elderly) then not have more 7135 / stronger FET than he actually needs for the HIGH mode, because he is then driving the LED inefficiently high?
It depends on what level you’re trying to determine efficiency.
In any PWM controlled light the lower the amperage is on high the more efficient the system will be in the PWM modes since the driver only has to switch 10% of 3A as opposed to 5A for example. As TomE already stated leds are more efficient at lower amperage and thus the higher the max amperage the less efficient the lower modes will be since the LED is still receiving 5A but for only 10% of the time for example.
To answer your second question it is more a case of safety rather than efficiency when children and/or inexperienced people are involved since most FET based (direct drive) lights run extremely hot on max. I would stick to lower output, current regulated (7135) lights for people unfamiliar with such hot rods.
Yes - of course a 7135 is a current regulator, but in a typical Nanjg/Qlite 7135 based design for one cell and one LED, it can easily fall out of regulation, therefore run at lower amps. For example, I can build up a 5.6A Nanjg driver with 16 350 mA 7135's, but for a Panasonic B cell and an XM-L2 on copper, I cannot achieve getting 5.6A, maybe only 3.5A or 4.0A at tops -- it falls out of regulation -- is this the right terminology?
Yes - of course a 7135 is a current regulator, but in a typical Nanjg/Qlite 7135 based design for one cell and one LED, it can easily fall out of regulation, therefore run at lower amps. For example, I can build up a 5.6A Nanjg driver with 16 350 mA 7135’s, but for a Panasonic B cell and an XM-L2 on copper, I cannot achieve getting 5.6A, maybe only 3.5A or 4.0A at tops – it falls out of regulation – is this the right terminology?
It can only "fall out of regulation" if it has been in regulation.
But then it might be in regulation with a fresh battery and no ammeter in series.
Truee HKJ - thanx!
NICE!!!
I didn’t get a connector so soldered the wires on and got it working first try! jinx … Backed up the firmware on the chip following the wiki. But wanted to ask- what software would you recommend for programming and a good firmware to start with that supports the eswitch? I seen in the wiki they say the BLF-VLD is a good start. I seen comfy had a cool firmware in that dropbox Tom posted too.
Is AStudio 6 any good? I’m running all this in a vm using xp (I know but… when in rome) if that matters.
Use this: http://75.65.123.78/RocheF6/F6DD_beta/
OoooO Thanks comfy… Installed Eclipse Luna- But it says my hardware doesn’t support the tiny13a when I go to load the mcu. Guess have to manually flash the compiled. I got quite a few different source files it’s kind of out of control! Jonnys and Toms had some nice ones I went through the other night. Dr Jones had like 3 of them that were pretty nice and strait to the point too.
I gotta say it’s nice to see people sharing source and bothering to comment on it too
Since you have avrdude working, just copy/paste the line from the .bat file.
That was a nice thing to do man… I finally got eclipse working and building, burning the firmware but I’m not up on the fuses. I found a good site to set the bits you want but I don’t want to brick it. http://engbedded.com/avrdude
I see in the avrdude bat you set the Upload Fuse 00 low 75 high. And the memory lockbits 255? FF Is that what the -UhFuse setting does in avrdude?
Maybe I should set the bits once in dos and not set them in Eclipse. It only seems to work using Tiny13 anyway and I can see something going amok there.
Getting eclipse building was kind of a pain in the ass. I finally got it to build and burn without errors, when tried to upgrade avrdude- it went back to spitting them out… So using the older version and put MinGW paths into c paths and symbols. It plays nice with the debugger finally.
I just saved a snapshot of the vm. Looking at your code. I switched STAR3_PIN and SWITCH_PIN around so I don’t have to reconnect that thing but going to test in the morning. My wife is trying desparately to get me off this computer. She texted some leg pictures but it’s nothing I haven’t seen a billion times lol
Are you on Windows, or not? Hard to figure out just from indirect stuff. If so, just double-click the .bat file and it opens avrdude and does everything for you, that's what it's for, so you don't have to figure out and type the commands each time you want to flash the same firmware. High & low fuses are already specified, lock bits are not because who cares with an open-source firmware?
If you're on something else, open the .bat file, copy the command string, and paste it into the avrdude window (assuming you've opened avrdude from the same folder where the .hex file is, otherwise navigate to the right folder first).
Ah nm… I see now It’s 75 hex low and FF high, leave the memory lockbits alone. Yeah using Eclipse, just wanted to make it all automated without using the command line, build and burn you know. I’m a linux guy but running this in a vm on a stripped install of windows xp. I could move it over to linux I guess, but this is good enough.
I think posted the wrong link last night it’s AVR® Fuse Calculator – The Engbedded Blog
Yeah I’m still at the start ready to run. I haven’t really got around to modifying code yet, but it should be fun getting the modes I want. Was thinking of making the yezl ramp up and down between clicks and put in your crazy fast strobe on hold of the eswitch.
The F6DD beta is a tweaked version of ToyKeeper's SRK firmware. Mode order default changed to short press = higher, long press = lower, long press duration dramatically shortened (from I think 35, down to 17), press & hold and it steps down levels until you release, or it keeps going all the way down to 'off' if you keep it pressed. It still uses her hybrid thing of phase-correct on levels 1 & 2 (gives less light output with the same PWM number, so helps get a lower low/moonlight), and the non-whiny fast-PWM on all other levels.
If you go messing with the fuses without also changing all the relevant bits to match you'll totally throw off the switch timing. So don't do that. No need to change any of that.
