It is in the better end and looks like a good option if you often need to charge many 18650 batteries. For fewer batteries of different sizes I would select a charger where you can select charge current.
I don’t think so.
Enova All-80 charge rate is much better than I4. Enova All-80 charge current is 675mAh*8; I4 charge current is 375mAh*4 or 750mAh*2.
Enova All-80 have 8 channels, Each of the eight battery channels monitors and charges independently ; but I4 _.
We have Enova All-41 similar to I4.
I don’t think so.
If somebody is interested in Enova All-80, for themselves , give them discount price ; for their business, give them wholesale price.
If you have any questions ,PLS don’t hesitate to contact me.
My email: sales1@enova18650.com
I just got mind today to from Mountain Electronics. I’m glad it came with this upgraded charger, which seems to be more robust than the little white one from the review. I’m loving this charger, and testing it with 4 Tenergy “D” 10,000 NiMH cells. Works great and charging them up quickly too.
I will take a picture of the new power supply. It is more like what you would expect from a typical laptop power supply, with the switch mode adapter sitting in the middle of the separate AC and DC power cords. Testing the charger with 8 cells at once the power supply barely gets warm at all, which is a good thing.
If you click on the link I provided in the previous post I have a pic of the upgraded power-supply, I like it much better than the one posted in the review here. Yes it looks just like a laptop power-supply and doesn’t block 2 outlets while it is use and runs cool
I bought the ENOVA ALL80 with the original wall plugin power supply. It blow sparks just like unplugging a running power tool every time its plugged in or unpluged from the wall outlet. The charger works great and holds 8-26650’s with just a little jiggling to get them all in. All channels appear to be independent, no current dips or drops when additional cells were added. A different power supply was needed, I hope that these new ones work. I’m stuck with the old style so I use an extension cord to protect the wall sockets.
Nice to see an 8bay version of the i4. USB output comes as a surpise bonus. I could be interested if the price was good and power supply was tested to be on par with needs.
Actually the price is good and so is the upgraded power-supply; it’s not exactly an expanded version of the i4 because ALL 8 slots are individual channels; so it is actually even better than the i4, less heat & better charger than the i4 which if you read all the reports on the i4 I think that one performs rather poorly.
sales1@enova18650.com Emailed me today to tell me that they had sent the original style power supply with my order and that production model is using a newer power supply. They will be sending me the new power supply. If they keep up this kind of service I can see myself buying more of their stuff. Honestly I’m a little surprised and a bit happy they thought enough to care after a sale.
