Convoy S3 - highest continous current?
The light will tolerate more than what you can get from a single cell into a single LED. Assuming, of course, the LED is on copper. The light itself is not going to be the limiting factor.
comfychair is right about the LED. “Lumen maintenance” may be less than ideal, but you probably won’t kill it. I don’t think that the battery would vent even from repeated DD with an XM-L2. The battery will have a lower total number of cycles due to the heat.
(You shouldn’t base your safety on my assumptions though.)
I 'test' them by dropping in a freshly charged 25R, switching it on, tailstanding it on the table until the low voltage protection in the driver shuts itself off. Never had one not survive that. You would need asbestos gloves to hold it while doing that, but it doesn't damage anything in the light.
Nice!
i don’t care much about the host, not much to be damaged there, perhaps the o-rings or the reflector, but it’s pennies. I am somewhat concerned by permanently damaging the emitter thus reducing it’s output.
I am though more concerned about the battery doing the thermal runaway.
so perhaps I need to do a test to verify if something will get damaged.
Test it yourself if you like, but you aren't going to be running at higher currents than I do/did. These are direct drive lights with hot INR cells. The single LED lights run at a little over 5A, the triples are closer to 10A.
I’m running it max with 2.8A measured at the tail cap (8*7135), the reflector section of the light gets hot very fast. The star is aluminum, using very high quality thermal paste (gelid gc extreme).
What hosts did you use for the triple emitter lights when testing? I guess you know, but Convoy s3 is a pretty small light, just a tad bigger than the 18650. It’s got direct thermal path shelf for the emitter.
I have built several S3s. Single XML2 & XPG2, and a few triple XPG2s. You cannot make enough heat with only one cell, and the LED or LEDs on copper, to damage anything inside the light.
A quality cell should allow for non direct heating(say placing it in the oven, not attacking it with a blow torch) from ambience temperature to 130c for 60 minutes with no fire or explosions :slight_smile:
I wonder about hung lights vs tailstanding lights .
The heat hitting the battery harder since it's above the emitter .
that happens because of hot air streaming upwards, don’t think it’s significant in these cases.
keep in mind the li ion battery could get hot enough to make it dangerous, while the light is on and internal damage that does not become apparent till it explodes in the future
thanks for the info!
I feel safer now :slight_smile:
I can understand that. I'm wanting to find a way to log temperature in my high current battery tests. All I know right now is that some of them get hot enough that it hurts to touch and further shrink the wrapper, so I wait a few minutes before removing it from the battery holder.
I heat only rises where a convection current can exist. So in liquids and gases yes, but solids no.
Comfy when you are saying you can’t kill a light on a single cell, is that assuming a certain light model, copper base, and good thermal paste? Or just in general?
I think in reality in setting the light down to run on max on its own, the more probable concern is more what could a running S3 set on fire if you set it on the wrong material, or had someone try to pick up the hot light and reflexively drop it…
On any of the single cell small pocket lights. Threaded pill, integral shelf, fins or no fins, doesn't matter.
I only use cheap white MG Chemicals silicon-based paste in the big bulk 10oz tube... I keep going on like a broken record about how at these power levels the Miracle Homeopathic Nano-Quantum Astrology Paste doesn't perform any better, but nobody wants to hear it.
It’s impossible to have a sane conversation on this since neither side has empirical data. Or has that changed?
EDIT: Added my emphasis in the quote in case it wasn’t clear what I was referring to.
You can kill a LED on a non-direct-thermal aluminum MCPCB with a single cell even if said MCPCB is bolted to a 16-ton piece of copper.
