I have built several S3s. Single XML2 & XPG2, and a few triple XPG2s. You cannot make enough heat with only one cell, and the LED or LEDs on copper, to damage anything inside the light.
A quality cell should allow for non direct heating(say placing it in the oven, not attacking it with a blow torch) from ambience temperature to 130c for 60 minutes with no fire or explosions
keep in mind the li ion battery could get hot enough to make it dangerous, while the light is on and internal damage that does not become apparent till it explodes in the future
I can understand that. I'm wanting to find a way to log temperature in my high current battery tests. All I know right now is that some of them get hot enough that it hurts to touch and further shrink the wrapper, so I wait a few minutes before removing it from the battery holder.
I heat only rises where a convection current can exist. So in liquids and gases yes, but solids no.
Comfy when you are saying you can’t kill a light on a single cell, is that assuming a certain light model, copper base, and good thermal paste? Or just in general?
I think in reality in setting the light down to run on max on its own, the more probable concern is more what could a running S3 set on fire if you set it on the wrong material, or had someone try to pick up the hot light and reflexively drop it…
On any of the single cell small pocket lights. Threaded pill, integral shelf, fins or no fins, doesn't matter.
I only use cheap white MG Chemicals silicon-based paste in the big bulk 10oz tube... I keep going on like a broken record about how at these power levels the Miracle Homeopathic Nano-Quantum Astrology Paste doesn't perform any better, but nobody wants to hear it.
Which do you think would make me happier, data or Never Never Land? The best data we have so far is from tests like this one by pflexpro, which does not directly address this topic.
Yes, good thread, unfortunately Fujik vs. solder is not the kind of thing I am advocating, not at all. Why do my arguments always get twisted around to "ha! he thinks we should all be using lights made of Fujik, asbestos, and styrofoam, lol!"
Look at that and then explain how you get more light with excellent thermal paste under the star vs. average thermal paste under the star. The farther you get from the source of the heat the larger the contact area, which makes each joint less and less critical.
The substrate is pretty good stuff, but it will always be compromised since it also has to still be an electrical insulator.
But still, if there's no heat sag, how is a copper pill or better paste going to make more light come out? If the Tinkerbell theories are correct, why does a light with an aluminum pill and crappy paste not show any significant dropoff over time? The initial output is going to be the same no matter what since none of the downstream parts are saturated yet, right? So where in all this is the extra light output supposed to come from?
are there any tests showing difference in emitter temps on copper star vs. Aluminum star? I’ve got some emitter l emitters on aluminum so it would be good to know what are the max currents/temps involved.
I had some trouble following what you are saying in post #25. I’ve previously read djozz’s post you linked to. I glanced over it again just now. I’m still not really clear about what you want me to be looking for over there. Do you have a specific thing you want me to observe at that link?
[I understand the exact nature of what you are trying to express *and I think that it is incorrect.* I think I made a clear qualification when I linked to pflexpro’s post. It had nothing to do with twisting around what you were saying.]
Not sure if applicable for flashlights, but here’s my experience with different thermal pastes:
When I was younger I was really into the self built gaming computer thing. When a high power processor, specially a video card was overclocked and pushed into high loads it produced an insane amount of heat, and can only lowered to decent temperature by the use of a water cooling system or a huge copper-base heatsink with massive fans.
When upgrading from a ceramic based compound to a high-silver one, I noticed up to 15° C drop at high loads. This drop might seem small but it gives plenty of room for overclocking.
BUT, we are talking about a processor which is much more sensitive to temp changes with an area much larger than any LED MCPCB, instant temperature raise on load, it could be idle @40° C and only seconds later at 90° C, this is really when the thermal compound plays an important role. A LED in the other hand is far less complex (greater heat tolarance) and doesn’t heat up as fast.
I have many times intentionally and unintentionally left a light on the highest setting and get an actual burn when touching it, and never killed one, or permanently reduced its output.
So in flashlights, I do think different types of thermal compounds makes a small difference, but in most, if not all cases these differences are so tiny that only exists in paper.
If this is really the case? Why do we all obsess and observe measurable differences when using AL vs CU mcpcb? (Same goes for water blocks and heatsink a for computers.)
Fast heat or slow heat aguement makes no sense to me, it needs to get out.
Even when your computer is idle at 40C, it would be more like 45C if you used cheap thermal paste or applied too much, or had a poorly lapped heatsink, or a small fan, bad enclosure ventilation, etc.
It’s all part of a system that works together and every part makes a difference all the way to the end.
The faster the heat transfer, the better it is for the emitter, driver, CPU, ram, north bridge, caps, whatever it is.
When talking about thermal paste in a flashlight, yes it’s further down the line after the mpcbs, but it doesn’t mean that it doesn’t make a difference.
To each their own thoughts about the subject really.
