So this single Ver 3.0 will be able to be built as a standard driver, or a Zener driver, easy peasy? Very cool.
I need to get some more components…
It will work as a zener, with no possibility of voltage monitoring (which isn't important to most of us anyways). Maybe it's time to just switch to a layout where the voltage divider doesn't pass through the diode on any of these, since we're all using custom programs anyways. Same resistors could be used for single cell with a slight bump in the ADC values.
Ahhh, ok, that's a "good-to-know" loss ??? You are losing me here. Speak slower . Why is it breaking voltage monitoring? Why is that not a major loss? - thought that can be worked out. I can't follow this....
I should clarify: with no voltage monitoring with 2S+ cells and the zener diode, since the voltage divider is downstream from the zener diode they will always read the zener diode voltage with 2S cells instead of actual cell voltage.
Ok, so this PCB has a potential design flaw - not sure purposely or not, at this stage, or is it even a loss if the firmware is not doing voltage monitoring for zener mod configs. Need an explanation from CK.
CK? Please?
It's not a design flaw, since none of the zener mod drivers you've ever used probably even had voltage monitoring before. You either gain voltage monitoring for zener mod or you break the traditional 120/130 ADC value compatibility for 1S cells, since the voltage will be be about 0.25V higher at the voltage divider since it isn't being dropped by the diode like it does in the typical 105C circuit. It is just a compromise.
You don't need the voltage monitoring since you can see that the light is getting very dim anyways, it is more for newbys and accidentally leaving the light on.
I was just saying that if we went to bypass the diode it wouldn't be a big deal anyways since we build these by hand, flash them ourselves, and could just flash the file with the changed ADC values to compensate for the 0.25V higher divider input voltage.
If you're not sure what I'm talking about, look at the voltage divider circuit on the typical 105C / BLF17DD and compare it to the BLD17DD-Z.
Richard, when did you have the time to learn Greek and why are you speaking it here?
Ouch - this hurts . All I know is that the zener mod drivers I built all had my firmware with voltage monitoring and I had thought it worked, but found out later it's all off. So, I thought it was fixable by using different threshold values based on 2S or 3S cell inputs.
I'm afraid if I look at voltage divider circuitry, I won't understand a damn thing about it. Think I'm lacking some of the basics here... Sorry Richard, I have no idea where this leaves my understanding of this issue. No possibility or add a compensation? I'm 110% confused...
For starters, here is the voltage divider math you use to figure out which ADC value to tell the software:
ADC = ((V_bat - V_diode) * R2 * 255) / ((R1 + R2 ) * V_ref)
IF DIODE PRESENT
So for our typical 125 or so ramp down at about 3V at the battery, we get this:
126 (rounded) = ((3V-0.25V)*4700*255)/((19100+4700)*1.1)
OK, now take a look at a picture of your standard 105C driver or even the regular BLF17DD. You will see that the voltage divider circuit positive input runs through this sequence:
BATTERY-->SCHOTTKY DIODE-->VOLTAGE DIVIDER-->MCU
The Schottky diode drops the voltage by about 0.25V (it's forward voltage). So, we compensate and tell the software that we want to ramp at about 0.25V lower than what the divider seeing and converting into the lower voltage for the MCU to check against its 1.1v internal reference voltage.
If you take the diode out, you get this sequence:
BATTERY-->VOLTAGE DIVIDER-->MCU
There is no longer the 0.25V drop across the diode, so no compensation is needed.
With the zener mod on the normal circuit, here is what we get:
BATTERY-->RESISTOR-->ZENER DIODE (parallel)-->VOLTAGE DIVIDER-->MCU
Since the zener diode is going to be regulating at a constant 4.1V (the 2S input voltage will always be far above that) the voltage divider will only ever see 4.1V. If you bypass and just go BATTERY-->VOLTAGE DIVIDER-->MCU you don't have that problem.
Again, voltage cut off really isn't a big deal on anything except for buck drivers as long as you are monitoring the light, since you will see it getting very dim before the batteries get too low.
You can use a wide variety of divider resistors, as long as the ratio is correct for what you want. Higher value resistors are generally better. Let's do a quick example for 6V with a R1 of 30K and R2 of 4.7K:
188 = (6V*4700*255)/((30000+4700)*1.1)
The higher the value of resistor the less loss you get through the divider. You also want to end up at a higher ADC value such as 180 vs. a value like 50 for better resolution.
I agree with RMM, he is pointing out the same problems I’ve brought up in other threads. Running the voltage divider from behind the D1 placement is a bad thing. I only did it on the 22mm 7135 driver because I didn’t feel like having the conversation about either adjusting resistor values or ADC values or both. This will be a struggle for a while.
To be 100% clear: Tom E, you CANNOT get voltage monitoring to work with the traditional “zener mod” layout. Period. Modifying the voltage divider’s WIRING can get voltage monitoring to work. Modifying the values alone (of the resistors or of the ADC threshold) will not make anything work.
A voltage divider has 3 points: Vin, Vout, and GND. Proper wiring for a voltage divider is like this:
Unfortunately the default layout of a Nanjg 105c hooks up Vin to the back of D1 rather than to Battery+. In the case of a stock Nanjg 105c this just results in a lower and possibly inconsistent reading. Once the traditional Zener mod has been performed however Vin is now connected to a semi-regulated voltage source: the voltage the Zener produces. This will tell our measurement tool nothing.
The proper place to hookup Vin is Battery+.
EDIT: grammar, oops.
Ok fixed (along with the 15, 15.17 and 20).
To answer Tom’s initial qestion, I am using all of the 3.0’s, I am running the 15, 17 and 20 (with the vdivider downstream of D1), the only change I made was that one thing, changing R1 to input VCC directly from BATT+. I have more of each ordered (tho I’m 100% sure its fine)
I was one of the people that just didnt feel like messing with it on the zener mod’s I did with the old drivers…
edit: sorry it took so long to answer (tho Wight and RMM definitely had it under control), I have been having an extremely busy week and today was the worst so far, I still have 3 threads on totally different subject’s I’ve promised people I’ll have posted by today.
I'm sorry - I studied the classic Nanjg layout, re-read posts #125 and #126 above several times. another biq Q: where is the VOLTAGE DIVIDER??? All we have is resistors, a diode, and a capacitor, and the MCU? It can't be done in a classic layout, then what's the magic layout it will work with? And if it exists, why doesn't it exist in our custom boards?
I think I need pictures or something...
The Voltage divider are the 2 resistors 1912 and 4701. Together they determine what the voltage drop is over the cell. Is that right?
Tom. I hate to say it, but it has been right under your nose the whole time...
Yeah, I am gonna link to Wikipedia.
What are the chances of that- today I neded a 22, boards ordered, if they run I’ll share them in about 2 weeks.
Ok - "think" I understand this better. The C_K (Dan) BLF 3.1 version here on OSHPark is now 100% - no objections? I see he's got the "voltage divider", i.e. the R1 and R2 resistors, totally independent of the diodes, either standard Nanjg or zener. So to do proper voltage monitoring, you will have to remove the 0.25v subtraction because it's no longer in the monitoring circuit. So this will effect all voltage monitoring that was previously based on the standard Nanjg layout, but in theory you should be able to do voltage monitoring with the zener mod configured.
Another issue I see is the e-switch is wired to pin #3 (PB4) of the ATtiny13A where previously we mostly used PB3. But you don't have to use his provide labeled SW+ pad, so I don't see a big problem there.
Also, there is no reverse polarity protection coming in on pin #7 of the ATtiny13A as there was before - I don't "think" this is a problem. Anyone care to comment?
Well I need to order more boards in all sizes, so, I think these latest from C_K are the best way to go. I was hoping for some feedback/comments before ordering... What he has listed in post #114 sounds awesome.
Ok - just order 3 of 15's, 6 of 17's, 3 of 20's.
Hey you think you could update with a digikey parts list for those new boards? Wonder if RMM will sell a updated kit soon too. I’m going to start making these too- looks like slapping lipstick on a pig really. Too expensive having them reflowed but I like supporting mountain.
My in-law is a contractor and does a lot of soldering. He had something else to do one day and asked one of the other guys to solder some boards up. He came back and the guy didn’t even solder the base- like big solder balls on all the ics xd Nothing was soldered. I thought that was funny- he called other day.
Wait - what do mean exactly by these new boards? The C_K boards, rev 3.1 shown as 3.0? (Confusing to say the least...)
The C_K boards are just a different layout than the standard BLF v1.0 boards, so it's the same exact parts list.
As far as I know, the parts list I link to in the OP at the very top (4th line) under the July 12th comment is the latest parts list and will apply to the C_K 3.1 boards as well. comfy re-posted the identical parts list link in post #92 for some reason, but he's got a very good explanation and description of the parts and the OTC option (OFF Time Capacitor) listed in that post #92 - please refer it to for more details.
Richard (RMM), as far as I understand now, does not use the same BLF 17DD or C_K boards - he's got his own versions, to his preferences, but they are close to the same thing, same parts list I believe.
I think the current state is 3 current sets of boards:
In my opinion, it looks like C_K's are the best, but the latest 3.1 versions are not actually tested, but C_K is very confident (100%) in them. I ordered C_K's boards but won't know of any issues or details til I get them and work with them.
Just to point out- yes I forgot to change the silkscreen on the board (still says 3.0) but the OSHPark upload is titled 3.1.
As Tom says I’m totally confident these work (Obviously I’ve designed a few other pcb’s, this is actually one of the simplest designs). I also still have a large quantity of 1.0’s left on hand- if anyone ordered a set of 3.1’s and they don’t work perfectly I will swap you for 1.0’s (one final time- you’ll never have to take me up on this).
