*Three brightness levels from 20 to 1020 lumens, controlled by a mode selector built into the head
*The M2X’s tactical tailcap switch features momentary activation and clicks on and off, while also providing immediate access directly to the brightest setting and strobe mode.
Is that the ribbed portion directly under the fins that is used to control modes? Magnetic? I suppose it has stops, as they list each position’s lumens output. But from a modders interest, that one point right there concerns me on what I’ll be able to do with this light. It’s obviously set up to run under 3A, I’d like to see it doing twice that. Maybe it’s just me.
Oh, and just exactly WTH is a “Javelot”? My cousin throws the Javelin in the Decathlon, reckon this is what they were going after? The long throw of the Javelin? Interesting…
In regards to changing modes at the “head”…………Probably works the same as my M3X and M22…
Basically loosen then tighten head,repeat process to go thru all Three modes.
Actually the M22 and M3X are a bit different.
M3X when Fully tightened is on MAX. Loosen a bit and it is on Low. Tighten and loosen quickly and you get strobe.
M22 is loosen/Tighten and repeat process to switch modes w/ strobe activated my 3 quick tail cap twists[!] or by a series of on/off half presses at tail switch!!
The word javeline comes from Middle English and it derives from Old French javelin, a diminutive of javelot, which meant spear. The word javelot probably originated from one of the Celtic languages.
Do you find it a PITA to change modes that way or is it something that you easily get used to?
I have a Eagle Tac TX25C2 that uses the rotation of the head to set low med high and while it can be neat, I don’t particularly care for it. I impulsively bought this one after playing with one that belonged to a friend, and overall the light is a nice light, but I don’t find myself using it often.
I agree,I do not like it! For my M3X it is usually on max so it is not an issue!
However, it can become a pain because I am walking my Dog! Sometimes I activate strobe if a Car comes. Another method to alert a car is vigorously move light from side to side,that works especially If I have my M3X that night!
Using Google translate reminds me of the old joke about an early computer translation program for English <-> Russian translation. At a demo of it someone put in the old saying “Out of sight, out of mind”. After translation to and back from Russian it came back “Invisible, insane”. Computer translation programs still leave MUCH to be desired.
The only good mode-changing is by separate button or rotating head. I want the dang thing to be in the SAME mode every time I turn it on since I will use momentary quite often. Also, since Olight drives their XM-L2s at 4 amps, this one - in order to have 1,020 lumens de-domed - would have to be pushed about that hard, and since Olight doesn't lie about their specs, I have no worries.
I saw your post. This is a very good price.
You brought the good news, but did not say the coveted coupon code.
Maybe you do good and publish a coupon code?
I think we’ll all be thankful. Your price is the lowest for today
At first the twisty action required at the head to change modes was kinda bothersome...I can't change modes one handed. But the more I mess with it the more I like it. The driver is actually quite sophisticated and well regulated. The body of the light is small, as befitting a single 18650 light. But the head is the size of an HD2010, with an even larger reflector than the 2010 due to a thinner bezel. It's a very decent thrower, holding current lower than I would have thought but still putting the light downrange.
I've found that if the normal mode selection is left in High, then there are no lower modes for the tactical switch (H-H-Strobe). If the head selection is in low, then the tactical switch at the tail has L-H-Strobe. If the head selection is left in Med, then tactical has M-H-Strobe. So there are options, easily set up without a lot of programming required.
Nice light, quality build, already de-domed. With a Sony C5 or a Panasonic BD, either way it's doing right close to 200Kcd and the same ~2.94A. What's not to like?
The close-up above is a nice one! Shows a super clean de-dome. Mine has some dome left under one of the bond wires, and the wires seem slightly pushed to the side. This just shows me that O-light is indeed doing the de-doming themselves.
