Freely assignable without consequence: you mean 5 pins, not 4? 8-3=5, or am I ignoring something again? You were referring to the pins that are left after we establish a voltage monitoring pin.
As far as the groups… I’d say the FET and the first 7135 get you repeatable Moon mode with PWM and maybe a small Low without PWM. The second set gets you up to a total of 2.28A for your regular usage mode, PWM free - so no buzz. With 6 spaces and the option for .35 or .38A components you’ve got a pretty granular ability to setup Medium/High for PWM free operation. With this 7135+FET driver I do agree that any extra sets of 7135 beyond set 1 and 2 are gravy; eg the driver should work acceptably without 4 outputs.
Note that v026 is posted above in post #63 and allows for the FET + 1*7135 + 1-to-5*7135 setup, allowing you to stop using Pin1 and still use all 6 placements if desired. If a temp sensor is desired Pin1 can be fused for use and setup as an ADC. [EDIT: and in that case you’d cut the trace and solder the temp sensor lead directly to Pin1, which is fine because you’d have to remove the MCU from the PCB for any changes anyway since it would require HVSP.]
I agree with the rest, but I don’t think HVSP is intended for in-circuit programming. If Pin1 is attached to Vdd on a 7135 then HVSP will take the 7135 out of spec: there will be 12v on Vdd and 0v on GND, I expect the 7135 to fry.
Since an FET is the least efficient on pwm why not have two sets of pwm 7135’s and the FET fixed (on or off only) and just use it for turbo. With 6 x 7135 that would give up to 2A on pwm and a genuine jump to turbo.
The issue is with using non-vector text, what “vector” is is text that each point / line corresponds to an exact coordinate so it will always be rendered / printed EXACTLY as it appears on the screen. Trying to use proportional text you will end up with the text slightly different, either shifted or miss-alligned or even contorted out of shape. I ALWAYS use vector. To many time’s I had boards that came with the text moved half way off the board or moved up to a copper area (and thus not printed at all) or some other way messed up, not once since switching to vector (and also centering it on the point) have I had a render / printing issue.
I cant tell on my phone screen, its to small, maybe it is but if not you really should use vector text.
I use vector text so that I can control the stroke thickness.
The issue was just that I was mistaken. I checked my BRD and Gerber files and the OSH Park render and simply became confused. The text is rotated incorrectly, I will correct this in the next version.
there is only one way to find out I what happens if you power a 7135 with 12V…
I looked in the data sheets I have and some rate it for 10V max on Vdd, so with a bit tolerance and good luck it will work. Or you have to add a jumper pad to the circuit which needs to be bridged to power the 7135 on the resetpin…or I just cut the trace and bridge it afterwards.
I will try to build a resetter and test it in circuit in near future.
I have thought again about removing the tiny for resetting and with a hot air this is a breeze, so a fuse resetter with a smd pad for a tiny could work like the one Warhawks has in mind. Just desolder it press it on the pcb with a finger and voila…
Interest has been expressed in not using Pin1 (Reset). There are not a lot of different pin configurations which make any kind of sense. Here’s what’s on my mind, please let me know if I’m missing something:
Pin 1 (Reset)
Pin 3 (on/off)
Pin 5 (PWM)
Pin 6 (PWM)
v029 trace config
Current/Original
3*7135
2*7135
FET
1*7135
c+a
alt Current (v026)
n/c
5*7135
FET
1*7135
a
proposed
n/c
FET
5*7135
1*7135
b
proposed
n/c
If anyone thinks it’s worth messing with for testing, I’ve devised a PCB which requires trace cutting before use but allows all 3 configurations (as a one-time setup option). I absolutely do not think that this is a great idea for most people building their own boards, as it is too confusing and trace-cutting in this location is basically one-way. This is really just intended as a semi-flexible test platform. Note that “c” is on the bottom and requires both cutting and a solder jumper. EDIT: “a”, “b”, and “c” all indicate CUTS which must be performed.
Yes. Resistor values for one cell are 22k/4.7k 1%. I’ve found those values to be acceptable. For a lower-voltage activation of LVP some may want to tweak firmware values very slightly I think.
> wight and ck
> (and me) …. torn off ground rings …
> rufusbduck
> I like the idea of lots of gnd ring vias to anchor the copper, also on critical led+/- pads. I like having some of the gnd ring vias a bit larger in dia to allow for ground wires
Yes yes from the sidelines here. Anything that puts more copper through the board, especially along the edges where it can be press fit to make a decent connection for ground …
I’d guess this is where homemade drivers will excel — being willing to spend a bit more metal to make something people can fiddle with a few times without destroying it.
Now if you could solder the driver board right into a retaining ring so the whole thing would screw down into the pill ….
I don’t think that the vias are as important as increasing the surface area that is covered with copper. In my experience: In only notice vias holding anything together once the copper layer is already lifted.
Not the same thing, but related: IIRC Solarforce uses a 16mm double-stacked driver which they solder into an adapter ring on the inside (eg during reflow I assume). this presses into a standard 17mm driver cavity. … again, assuming I recall correctly
Too bad I don’t have pics. GND is passed in the normal way (using a post/pin/peg between the two PCBs). Only the larger, bottom PCB is actually attached to the ring.
> if you don’t mind the emitter wires twisting
Yeah, I count the turns and pre-twist them the other way so they untwist as things screw together.
Extra wire, I know, but I need that just to get ahold of things to solder them.
