Gotta say, that image makes me want to break out the 5DMkII and the Hybrid IS Macro lens and have a go at it my own self! Pretty sweet, that!
Here's the emitter out of my Javelot. Obvious that it came with a dome on it...
I am hoping mine looks like jeter68’s!! We both got it from Illums,then again, they ALL came from Olight in China!
I will find out tomorrow. Bottom line is as long as the beam profile is not affected, it shouldn’t matter,I hope halfway bent bond wires would stay stable!
Oh, did you want to see bigger? I reduced it to about 70% (shot with A77/150mm macro)
you gots a messy one
I am watching too much emitter porn today lol.
Great picture from you too Dale, it looks like Jeter68’s emitter is cleaner.
The bit of silicone stuck under the wire sure indicates to me they de-domed it themselves. Remember that this one is off the star, has been re-flowed and replaced.
The 5D MkII is a full frame sensor with 21MP. My macro lens is only 100mm.
This looks to be one for my collection! Is a group buy possible?
Mine looks and works perfect!! Can not wait until it gets dark!
My LED looks like jeter68 except[this is picky/critical!] both my bond wires are perfectly straight!! lol.
As I mentioned to other people, it does NOT have that big of a head. The pictures make it look bigger. Just like it does w/ most lights. It is very compact.
For the hell of it I connected the entire body of the M3X and it worked. So those threads are compatible. the tail cap is NOT.
The light has impressive run time on max.
NO use boring you w/ all the readings!
I ran the light in 5 minute increments[step down begins], let it rest a few and then checked voltage. After 40 minutes of combined time the Voltage was 3.64V.
ohh,yah,Through the entire test This light is NOT even close to getting hot. Tail stand w/ no fan and temp. was 63F on my loft.
I also found that the BODY of the M3X fits the head of the M2X and the UI works the same. It is almost 1” shorter this way. With the light being so compact and the run times are very sufficient to me, I really have no desire to do that.
HERE is the picture.M3X Body w/ M2X head and M3x head next to it!
Photo bucket is the only way I know to get a pic. on here. Just click the “Link”.
Looks like the head is more compact, is the M3X reflector deeper than the M2X-UT? Does the M3X also have the massive copper star under the emitter? Looks like the M3X would be a considerably better thrower with it's own emitter dedomed, hmmmm.....
I really like the size of the Javelot. A mix of a compact single cell light and a large head thrower, keeping the traits as much as possible of both. Laser beam like, even with the XM-L2, I bet a de-domed XP-G2 would be awesome! :)
Thinking outloud here, as it were, but I bet a reverse resistor mod to bring current down to 2.4A and a de-domed XP-E2 would be killer in this light. Talk about a pencil beam... :bigsmile: Anyhoo. Just wondering out loud.
I just checked,the emitter is NOT any deeper inside the head.They seem to be exactly the same in that regard. The M3X has a few more fins on it and the head itself has more depth/length to it making it bigger.The circumference of the heads are the same and so is the reflector. I hope I explained that all right! I guess I could have said the reflectors are the same!
As far as the copper star.I have no idea!! I am not one who takes these apart because.
I can not mod them!
Time for dinner then off to the hiking trail! K40vn ~ 400Kcd, S200C2vn~ 130Kcd and the light of the night,M2X-UT ~165Kcd! :bigsmile:
Just take the bezel off and drop the reflector out, have a look at the star. I will show copper on the sides if it is the same as the one in the M2X-UT. The put it back together.
I like to take the bezel off with the light upside down. This lets the reflector sit in the bezel and I don't have to worry about touching inside it. Have a look inside, then put it back together upside down again until the bezel is close to seated...then I flip it and watch that everything is right before snugging it back down. Easy peasy! ;)
If you don't feel comfortable doing that, then please don't. Send me your M3X and I'll take it apart for you. :bigsmile:
Thanks Dale,it was a piece of cake!! The reason I was apprehensive was because there was a period of several months where the oring kept bulging out! I took it apart 10 times and did not want it to happen again!
Anyway,your trick of doing it upside down is very easy and effective! :bigsmile:
I believe they are the exact same copper stars. To the best of my ability[I did not want to take the screws off] I measured just under 1 7/16” You measured the M2X AT 35.6mm or 1 13/32”. I believe they are exactly the same!
Hey maybe you can turn me into a Modders assistant!!!
Now the pics.
http://s783.photobucket.com/user/capolini1226/media/025_zpsd5ad4b19.jpg.html
http://s783.photobucket.com/user/capolini1226/media/022_zpsbc5fbc0c.jpg.html
http://s783.photobucket.com/user/capolini1226/media/026_zpscdc09e74.jpg.html
M25C2vn[~300Kcd] and the M2X-UT. They are close in size. The M2X is 1/2” smaller. The M25C2vn has a more cone shaped, tapered and deeper reflector. I am guessing at least 1/2” deeper.
I wonder what those 2 wires are? The small ones attached to the star? The M2X-UT has those 2 points soldered, but no wires. Interesting.
I see yours says M31 on it, where my M2X-UT says M3X. Other than that they appear identical. And you believe the reflector is the same depth? Even though the head is deeper? Normally the longer or deeper head is only that way to house a deeper reflector. Again, interesting.
Assistant huh? Start taking em apart and putting em back together and the next thing you know you're a modder your own self. :P
I am just guessing,maybe the wires were attached and soldered underneath?
They probably go to a thermal sensor or something, measuring heat on the star in order to step the output down if/when necessary. That's the only reason I can think of to have a wire there, but don't understand why 2 wires.
I can plainly see black cows at 331 yds, and identify trees and the green leaves at 475 yds. It's even a wet hazy night.
I am sure that is not it because the M3X has NO step down! Thermal or Timed.
I will try to be succinct! I had a minor issue with mine that I have A LOT of experience with!This happened so much with my TK75 before I found a solution w/ help! Last summer[2013] I started a thread about it on the other forum.
I am not concerned it was just a bit of a bummer for the first time I used a light.
With in 5 minutes condensation formed under the lens and was there until I shut the light off. It absolutely affected the beam profile and blocked out about 70% of the light right around the hot spot.
Mr. M2X is now in quarantine like many of my lights have been. SOLUTION: SILICA Gel treatment!
Wow, with almost 80 lights in my collection I've never had that happen. Ok, never being a bad choice of words. I froze a light in the deep freeze at 0ºF overnight and then took it out and used it. Frost and haze was present on the Outside, but not on the inside.
The light is o-ring sealed against water intrusion, so the only way a haze or condensation could form on the inside of the lens is if the light is assembled under extremely humid conditions, trapping moisture inside. I guess if you open a light up and it's extremely humid (I would think it would have to be very very bad!) it might have moisture present inside when you reassemble it. I've never seen that happen though.
Strange stuff!
