I Just did my first laptop pull… My old Asus EeePC 1000HD with a busted screen kindly donated it’s battery pack. The battery pack name was PL32-901 and was rated at 8700mAh. It was easy to bust open and not much glue. Inside I found six cells which would be rated at 1450 mAh each. Edit: As pointed out below the battery pack was 7.4V, not 3.4V, so they are 2900 mAh each.
Oh? The battery pack had a rating of 8700 mAh on it. Divide that by 6 and it’s 1450. Is it common that battery pack ratings are not the same as cell ratings?
I looked up what voltage those packs the EeePC use run at, and they state 7.4V, and 3.7V nominal in 2S is 7.4V. Also I assumed the configuration is 2S3P after seeing the pictorial proof and capacity rating. In the end 8700/3 = 2900.
Now I want to go out and hunt for those high Wh/mAh 2S3P packs since I've never tore one open yet
A few days ago I tore apart a battery pack previously installed in an ASUS K52J series. The pack was rated for 11.1V 5200mAh and the cells inside were LGs. Specific model: LGABB41865 2600mAh
2 of them show 0V, I will put them in the battery recycling bins.
2 of them show 3,66V.
2 of them start off at 3,5V and then drop and drop and drop until they reach zero. They reach 0 volts after 10 seconds of measuring. I have disassembled a few packs and I’ve never seen such behavior. I’m measuring the voltage using a Fluke multimeter. Anybody has any explanation for this weird cell behavior?
That was the remnants of their ‘electrical soul’. You sucked it right out and killed them. :bigsmile:
Take a look at the fall off curve on lithium. These batteries were essentially dead and on the last tiny bit of the vertical component of their discharge.
You can do the reverse > take a freshly ‘dead’ battery, charge it for just a bit on a low amp NiXX circuit and it will rapidly bounce up to 2-3v but there is still essentially no capacity there.
Did my first battery pull today. HP 437403-541 met it's end. Unfortunately I do not own a multimeter so no voltage test for now. But I should be able to measure it at work.
As you will be able to see in the photos I found Samsung ICR18650-26C (Samsung SDI 775) batteries inside. Their data sheet says:
Samsung SDI ICR18650-26C
Nominal Voltage 3.6V
Nominal Capacity 2600mAh
Lithium Contents 0.78g
3.6V surprised me a bit, I expected 3.7V. Or is it normal?
Update:
One set of 3 showed 2V, other - 2.65V. Hopefully I'll be able to charge them.
That’s odd. Where did you come up with 3.6v? I found an MSDS from HP that lists these cells as 3.6v, but the Samsung datasheets out there list them as 3.7v. Looks like HP is using the 3.6v value on the pack too, since it is marked as a 7.2v pack. I wonder what it reports to the system over SMBus for both nominal voltage and capacity.
