Australia Based Deals / Info / Links / Discussion
Thanks George,
grabbed one.
Great price for charger and 4 eneloops.
$3.99 4D lantern at Repco (starts 20th Nov).
http://catalogues.repco.com.au/offer/lanterns-torches-outdoor-lighting/gearup-4d-battery-lantern/50nyivv3n.html?source=catalogue
The closest I can find is a Dorcy 4D lantern that looks nearly identical apart from some small differences, the incan gets 15 hours from 4 D cells and the LED version gets 220 hours (9+ days) both at 40 lumens.
Might be worth it if its the LED version.
G'Day Aussies,
Ends Friday 21/Nov/14 (Australian date & time):
Panasonic Eneloop Quick Battery Charger BQ-CC16 + 4 AA Recharg Batteries A$29.99 (K-KJ16MCC4TA) | Dick Smith
http://www.dicksmith.com.au/batteries/eneloop-quick-battery-charger-4-x-aa-rechargeable-batteries-dsau-pw0050
Best Regards,
George
Hahaha, you just copy and paste from OzBargains :wink:
Bigpond users:
You can double your monthly limit for free, 3 times a calendar year.
I just discovered this, so could use 200GB this month rather than my plan’s 50GB…
Aldi have “Coolabah BBQ Light” for $18
Metal, 3xAAA 12 LED
Looks suitable for a workbench light.
Might be a nice mod - put in a NW emitter, new driver and 18650.
I was looking to get some LED light bulbs so I asked Gearbest if they could generate some coupons for the ones that I was interested in. It’s not much of a saving, but buying at least three of them, you get a $1 saving the original price. All but one bulb is your standard B22 socket, with one being an E27. These coupons are valid for a month, so expires mid-January 2015.
http://www.gearbest.com/led-light-bulbs/pp_18475.html
coupon: B22CM
price:$3.39 (usual price $3.66)
http://www.gearbest.com/led-light-bulbs/pp_94584.html
coupon:SencartCM
price:$3.09 (usual price $3.33)
http://www.gearbest.com/led-light-bulbs/pp_113530.html
coupon:SMDDCM
price:$3.40 (usual price $3.74)
http://www.gearbest.com/led-light-bulbs/pp_118172.html
coupon:ESE27CM
price:$5.48 (usual price $5.76)
http://www.gearbest.com/led-light-bulbs/pp_70260.html
coupon: SencartB22
price: $4.59 (usual price $5.01)
I decided to try their LED bulbs by buying this first. Turns out it’s pretty good. So bought more of them to replace other fluorescent light bulbs around the house.
My local Bunnings had 3D Maglites on special, two different models for $29.00 incan and $30.00 led.
Do you know if they are the newer improved (brighter at least) LED model, or the previous one? The older one has a horrid donut but decent punch for alkaline power, the new one is supposed to be better in beam profile and lumens IIRC (although dont quote me on the beam, it might be wishful thinking).
I would guess its the older led version. You would only buy one to mod would you not?
I thought the genuine LED ones couldnt be modded, or not without a lot of work. The incan ones were the pick to mod? Or do i have that wrong?
I have no idea. I suppose it depends on the interpretation of modding. OL was not impressed with the latest (led) ones to mod but I dont believe that is what Bunnings have on special. I'll have to snap some pictures next time.
I just seem to recall there being a serial number on Mags D cells that was not suitable to modding, if youhad the one without that serial beginning you were good to go, if not it was some major work.
Still, $30 is a good price for a decent light. I own one of the older stock LEDs, great for throwing in the back of my 4by. I hate the donut ring but Ill get over it. I think they are XPE, they trow pretty well.
Was looking for wall ovens in QLD but found hundreds of lights in auction ending tonight 8pm AEST.
http://www.graysonline.com/search.aspx?q=lights+queensland
no, am not bidding on lights.
Happy Australia Day
Back up phone charger, Eneloop branded li ion single charge so its compact at just 2850mah. Not sure when it ends…
Under $10.
http://www.dicksmith.com.au/mobile-phone-accessories/panasonic-eneloop-mobile-booster-black-dsau-pw8952
Bugger, it’s ended. That’s what happens if you bludge an extra day after Aus day
Dont feel too bad, it ended a couple of hours after I posted in Qld, probably an hour in the southern states with their curtain fading, cow confusing daylight savings time. It was for Aus day only it seems.
I managed to snag two though.
Its back on today only. Does anyone know whether these are anygood and whats inside?
http://www.dicksmith.com.au/panasonic-eneloop-mobile-booster-black-dsau-pw8952
I have both here, one is on the PC to charge it fully. The led goes from red (30% or <) - orange (30-60) - green (60 - 100) as it charges. Cant say whats inside, there are no screws to pull it apart etc, I assume its glued or internal clipped. Not that I would know how it works even if I could pull it apart.
The instruction booklet states it has Overcharge, Overcurrent and Over discharge protection along with abnormal temperature detection. Apparently it can be placed on an IQ pad to charge too.
The head comes off, has fixed to it the std USB plug, and a short cable neatly fitted and wound in a slot with the Micro USB. You can pull the head and plug the USB to PC, and the micro lead into the side of the unit to charge itself from the PC/USB port. The head is them placed back on, the USB plugging into the unit, and the micro now being the output to the phone item being charged.
The lead wraps neatly around the head. Theres a power button along with the LED too and thats about it on the outside. Its a clever enough design… but I cant find any info about how it charges the li ion inside for example.
Internal battery max voltage is 4.35, max charge rate is 0.95a
Rated input is 5v, 0.50a/1.0a
Rated output is 5v 1a, or 1.5a if the 203 model and using both terminals (Ill assume it has dual outputs). This is the 103 model though.
Thanks EF. Would you consider this a good buy for $15.00 with shipping?
