on my horizon there are a couple of windmills.
i can light up one of them with my old light and it is approx 1.26km away when i use google maps to measure the distance.
it barely lights up but no hotspot.
as soon as i can do some testing with the uf-1405 i will post the results.
for now i will get a 26650 cell and a spacer cell to make it more solid
despite the desciption the driver I mentioned does not have low voltage alarm.
the seller i bought it from wants me to send it back.
I do not think this will help because I suspect the whole batch of drivers does not have low voltage alarm.
I ended up buying a more expensive 17mm 8x7135 driver($10) which hopefully does have the low voltage alarm as promised.
The stock driver in my light. Which is probably the same as the one in yours and most others have good current regulation (about 1,8A to the emitter) when input voltage is from 8,4V and far below 5V. I did not see any low voltage warning or cut off. It could easily drain unprotected cells below 2V without the user noticing. I would certainly recommend protected cells with that driver.
i replaced the stockdriver with a 8x7135 driver to make sure i get 3 amps to the led.
indeed the nanjg driver is not that expensive ($3 at fasttech)but the type i bought has a bit better finishing and a better spring.
i bought a 20mm version and i like it a lot
because of the bad exerience with a driver without low voltage warning i wanted to make sure i got something OTHER then a nanjg
i will use the 7135 from the other driver to boost the one i bought to 4 amps
this is the one i bought of ebay(yes it is expensive but quality looks similar to what i bought before and that one was really good.)
I put in a modded LD-40 with an R120 stacked on top of the original R100 resistor and 340kcd is the best I could get with dedomed XP-G2 S2 2B.
Current measured at tail is 2.60A with two 18650, that translate to 4.30A to the LED by estimation. I have modes problem with the LD-40 when using two 18650, may or may not fix it though.
did some testing tonight to see how far it would reach
i have 3 windmills at my horizon
windmill at 1270 meters, no problem, lights up in the dark sky
windmill at 1380 meters, no problem, lights up in the dark sky
windmill at 1610 meters, does not light up in the dark sky
so with a fully charged 18650 IMR and 3 amps to the XP-G2 led the range is about 1400 meters i guess.
do not know the light intensity but in the end range is what counts.
To those who are doubtfull of the range spotting of windmills I'll just add a few observations.
Windmills are oftenmost whitish/light grey.
They are slightly reflective due to this. The ANSI standard limit of vision (0,25 cd) is based on a non reflective surface. Removing this limitation makes almost any light have endless range as you could theoretically set up a perfect mirror the size of a barn to make sure your single aaa light had a 3 km range ;-)
I have spotted windmills at 900 meters with a ~35 kCd light (kCd measured by myself later).
Due to having no spill at all zoomie lights do not reduce your night vision as much as reflectored lights do as the "backscattered" light from the spill of a reflectored light plays heavily on your eyes. Especially high powered ones (lights that is. My Eyes do not require external power :-p )
LOL, I guess that I am so dutch that I only thought of traditional windmills. Now I see that it makes more sense if gravityZ referred to modern windmills :-)
i tried to get the pill out
like the first time when i got the light and lubed the sealing:
unscrew teh bezel, use needle nose pliers and turn
that was easy then
but today… lets say: if i had a swear jar i had to put a lot in…
the pill does not move.
in no direction (should be counterclockwise to get it out - right?)
any ideas?
could it be that the pill got a “bump” from the head when screwed out while zooming?
i will try the heatgun tomorrow…
-> i did not play more than 5 minutes since i got it
