LOL, I guess that I am so dutch that I only thought of traditional windmills. Now I see that it makes more sense if gravityZ referred to modern windmills :-)
i tried to get the pill out
like the first time when i got the light and lubed the sealing:
unscrew teh bezel, use needle nose pliers and turn
that was easy then
but today… lets say: if i had a swear jar i had to put a lot in…
the pill does not move.
in no direction (should be counterclockwise to get it out - right?)
any ideas?
could it be that the pill got a “bump” from the head when screwed out while zooming?
i will try the heatgun tomorrow…
-> i did not play more than 5 minutes since i got it
For one light I stacked 2 r150s on top of the r120 to get 2.6 at the tail from 1A stock. For the other one I swapped out the driver for a nanjg at 3A but more will be stacked to 5A
the windmills indeed are grey and used to generate power.
i do not think they are replective but since they are grey they will stand out the background more easily then other objects.
having said that i still the UF-1405 is superior because of the big lense.
i gave an exact same setup(8x7135 driver, xp-g2 dedomed, 1x 18650) in another zoomie with a 35mm lense. that one could barely light up the first windmill at 1270 meters and did not reach the others. so if that light is not able to do the job then a zoommie with a smaller lense or aa batteries is definately not going to reach it.
give me some time to should some photo’s
i will wait for ideal conditions and try to shoot a photo while lighting up the windmill.
last night had a clear sky but also a full moon which is not very good for contrast
Im late to the party. Been too busy with other lights the last weeks/months so my 1405 have mostly collected dust. I decided to do a simple budget mod instead of bringing out the full potential of the light.
Total cost of my light with mod: 31,15$.(or at least below 32$)Throw457kcd.(or over 500kcd with very high calibration)
Longest throwing light in that price range in the history of BLF?
Feel free to add an additional 7-14% to my kcd number to get closer to the highest readings meters. (That means 500+kcd). Ive measured my light twice at 15m and once at 5m, after 30 sec.
Well done! Of course I would like to know which emitter, driver etc. And what you consider to be the full potential. You are being a bit too concise here, RaceR !
I botched the dedome on this XP-G2 S2 2B |( but it still gets 422kcd measured at 10m from 2 stacked R150s 3.6A at tail.
I need more practice with the heat method.
There was no tint shift as far as I could tell from dome on to dome off.
Here’s the one with the 3A Nanjg 1A dedome next to stock 439kcd.
Hi Chazzy, your mod is interesting but there are something I don’t understand about.
Assuming the stock driver delivers 1.60A to the emitter before modded. By stacking two R150 on top of the R120 it should give you about 4.16A to the emitter (neglect the losses) isn’t it? If you measured 3.60A at tail that would be translated into a whopping 6A to the emitter!
In your case 3.0A + dedomed XP-G2 S2 2B = 439kcd
In my case 3.5A + dedomed XP-G2 S2 2B = 310kcd only
That is almost 30% of difference. I used my HS1010 to measure and convert the reading from 4.5 meters. May I know at what distance did you measure the lux reading?
