New 105D. replacing Nanjg-105c @ FT? (no stars!)
Well, I do not notice the PWM so much on these drivers. But I know others do not like it.
Can you make LD25 driver with moonlight too? How low can the current be for moonlight?
I would like something like <1 lumen - Low (5) - Medium (30) - High (100%).
THAT IS AWESOME! Does this mean I can reprogram the driver to have the modes Low, Medium then High instead of high first? Also, does the brightness programming change the output of strobe and SOS as well? Thanks.
Awesome! Didnt knew that. :party:
Can you do that for each mode??! :open_mouth:
Yes, please see this thread:
video of LD25 output current setting ,wish you success!
Thanks wight!
Thank you!
I also got 3 of those 105d drivers instead of regular ones, and i was refunded, in the opened ticked a guy assued me there those shoudlnt be even in the store
And mine didnt have memory too
From now on will order 4 mode ones
I had the same issue and opened a ticket because I always use the stars for switch/offftimecap.
Put mine to good use :slight_smile:
Quite nice to have a symmetrical layout on top for stacking and making improved thermal paths. Glad I got a few of these by accident.
Thanks Werner, good to know.
Looks like FT updated their listing pictures for the 2-group '105c'. Yet to update the title, description and specs.
Came across this tonight.
http://www.kaidomain.com/product/details.S023811
http://www.aliexpress.com/store/product/2015-Arrival-Free-Shipping-Nanjg-105E-AMC7135-x-8-MCU-3040mAh-4-Group-2-5-modes/809204_32259022955.html
I don’t see what the extra three resistor spots are for.
Heh, interesting.
The stars on this version, while functional, are mainly for show. R3/R4/R5 are where you easily bridge each star to GND. A pick-n-place machine or assembly worker can easily place a zero-ohm jumper across those pads.
stars for bridging :stuck_out_tongue: throw some 000 resistors on the pads, if you look close the star is connected to one side of the resistor pad, the other side is connected to ground
Most definitely odd, but interesting on the new revisions of the 105 *7135 type drivers
ding ding ding :slight_smile:
http://www.aliexpress.com/store/product/Diameter-20mm-4Groups-AMC7135-8-Flashlight-circuit-board-Anti-reverse-output-current-3040mA/330416_32266600994.html
