Adjusting medium mode only?
every mode can be set ,this is just a example
Which is the upper limit of high mode?
i will ask the manufactory ,i set the high mode 3.1A before
Cool!
This can be done on all (old) LD-25 drivers?
yes,you can try
about 0mA to 3100mA, every mode
Cool
Thank you Simon. Also, well done with your video skills.
Thanks, Simon!
Can you ask the manufacturer, please - is there some way to disable SOS and strobe permanently?
I often use my flashlight just for the couple of seconds, so I unintentionally activate these damn blinkies all the time |(
I have to wonder what the ld25 tops out at with some resistor modding. I guess i will order some and find out
Can you make the strobe slower?
several days later ,i will have LD25 with these modes: low-mid-high (hidden strobe,switch by double-half-pressing the tail button)
Thank Simon,
I wonder if we apply this trick with the KEY contacts on LD-33?
I’ve seen HKJ wrote in his review of the LD-33
“The ”Key” is not a mode change or a on/off switch.
It will increase the led current slowly when shorted, it goes up to 3.5A led current. The increased value is stored for that mode and I did not find a way to reduce the current again. I.e. my driver now has 3 modes, each with 3.5A through the led.”
i will ask the manufactory how to reduce the current of LD33
the set method as the same as LD25
- To increase current, hold “set” to “ground”.
- To reduce current, “tap tap tap” “set” key to “ground”.
Is that correct?
right
