Thanks Simon.
I really don’t like the 5% - 50% - 100% of LD33.
uh….i guess you hate it because there is no big difference between the mid mode and the high mode
I would suggest yes and I agree.
Thanks!
Not a lot of seller understand our thoughts as well as you do.
can the new LD-40 be done the same way?
cannot see it ,cuz it said ,it is unavailable in safety mode
Does the LD-40 have a set key aswell?
I hate to dig up old threads but I had some questions about this procedure. I recently bought one of the “older” (block knurling). Convoy L2’s with the LD25 driver and thought I’d check out the video.
Questions:
- Is that a voltmeter he’s using to supply the current? And if so, would an average battery powered Harbor Freight cheapie work?
2: How do you know what mode you are adjusting?
3: Does raising the current make the light brighter? If you raise HIGH up to 3.xx amps, is it putting out more lumens? Thanks
