A few days ago I tore apart a battery pack previously installed in an ASUS K52J series. The pack was rated for 11.1V 5200mAh and the cells inside were LGs. Specific model: LGABB41865 2600mAh
2 of them show 0V, I will put them in the battery recycling bins.
2 of them show 3,66V.
2 of them start off at 3,5V and then drop and drop and drop until they reach zero. They reach 0 volts after 10 seconds of measuring. I have disassembled a few packs and I’ve never seen such behavior. I’m measuring the voltage using a Fluke multimeter. Anybody has any explanation for this weird cell behavior?
That was the remnants of their ‘electrical soul’. You sucked it right out and killed them. :bigsmile:
Take a look at the fall off curve on lithium. These batteries were essentially dead and on the last tiny bit of the vertical component of their discharge.
You can do the reverse > take a freshly ‘dead’ battery, charge it for just a bit on a low amp NiXX circuit and it will rapidly bounce up to 2-3v but there is still essentially no capacity there.
Did my first battery pull today. HP 437403-541 met it's end. Unfortunately I do not own a multimeter so no voltage test for now. But I should be able to measure it at work.
As you will be able to see in the photos I found Samsung ICR18650-26C (Samsung SDI 775) batteries inside. Their data sheet says:
Samsung SDI ICR18650-26C
Nominal Voltage 3.6V
Nominal Capacity 2600mAh
Lithium Contents 0.78g
3.6V surprised me a bit, I expected 3.7V. Or is it normal?
Update:
One set of 3 showed 2V, other - 2.65V. Hopefully I'll be able to charge them.
That’s odd. Where did you come up with 3.6v? I found an MSDS from HP that lists these cells as 3.6v, but the Samsung datasheets out there list them as 3.7v. Looks like HP is using the 3.6v value on the pack too, since it is marked as a 7.2v pack. I wonder what it reports to the system over SMBus for both nominal voltage and capacity.
Just Googled markings on cell and found their data sheet on HP’s website. Probably the same you were looking at. Won’t be able to tell what it reports to the system because it’s a random battery I purchased on internet.
I dropped by the retail store of a PC recycling shop yesterday and picked up some used packs for $1 each. Pickings were pretty slim and mostly DELL from the late 2000s. I am pretty turned off Dell after the shitty quality and poor yield of a bunch of 6-cell packs I took apart a few weeks ago, but I’d made the trip, so I decided to pick up 5 packs and get a broader view of Dell’s battery pack engineering.
The first of two Dell Type TC030, 11.1v, 85 Wh packs I tore into was labeled as having Korean cells. Once I got the pack open, I saw they were teal LGDB118650 cells, which are rated at 2,600 mAh capacity. They were arranged as 3s3p.
The voltage of the pack, measured with a multimeter was 8.25v. The individual banks, starting from the positive end of the pack were 3.78v, 0.8v and 3.70v. When I pulled the first bank of cells apart, I found that the welds were strong and intact, but I saw the problems I saw with the earlier 6-cell packs: The cell voltages within a bank weren’t uniform. Two were ~3.78v, but one was 0.12v.
Concerned that I might have been breaking an internal weld when tearing the nickle strips free at the negative end, I took more care with the next two banks, disconnecting the positive terminals and measuring voltages before tearing the strips at the negative end. Even so, each bank contained cells with major variations in voltage, something that shouldn’t be happening.
Out of 9 cells in the pack, only 4 had voltages above 2v. I’ve run them through a charge/discharge cycle @500mA on my Opus and they all have about 1,500mAh capacity, or just 57% the original rated capacity. Update: it looks like these cells are supposed to be charged to 4.35v. I can’t find any comparisons of how much capacity is sacrificed by charging to 4.2 for these specific cells, but it looks like other LG cells give up 10-15%, which would put these at 1,660-1,750mAh, or 2/3rds of the original capacity.
According to PackProbe, the pack has seen 186 cycles, and was manufactured in the summer of 2007. This seems to me to be above average wear-and-tear, perhaps not surprising given that all the banks had at least one bad cell and are 7 years old. The datasheet for these cells indicates that they should retain 75% of original capacity after 300 cycles.
I have started tearing apart a superficially identical pack that is marked as made in Japan. It’s actually quite different.
Oh wow I didn't know these were 4.35v cells. It probably explains why they come out to that capacity range when I ran a set through my Lii-260 (far right).
Tore apart my old Gateway battery that I have replaced. The nonfunctional SQU-715 yielded 6 Blue LG 18650 cells labeled LGD5318650.
Right out of the pack each cell tested at over 4v and have taken a full charge from my OmniDok.
I don’t have a way to test the capacity of each cell, nor do I currently have a way to test them. I’ll edit it when I get my Opus in and can do a capacity test.
