Uniquefire UF-1405 - A worthy zoomy?
gearbest is sending me one for review
Yeah I think so, aspherical lens might behave a little different with the reflector. I wish I could try to measure mine at a longer distance but it is inconvenient for me to do so.
By the way I have fixed my LD-40 driver last night and I still only get 310kcd out of it though. Well I think I will just live with it, at least it is running with a buck driver which is always my preference. :slight_smile:
Hiya fellas!
Ok I’m getting tempted to order one of them there UF-1405’s.
But from where? I respect Djozz’s opinion, looks like he got his from Gearbest, other got there’s elsewhere. So I’m slightly confused there.
And I’m definitely confused about all this 7315, Nanjg, Buck driver techno-speak too.
What’s wrong with a dedomed XP-G2 or and XP-E2 (both from Hank….in the past) and having it direct drive?
Eh?
Wassup with that?
Eh?
Hi Rob, haven't seen you here for a while. There is nothing wrong with a good direct drive, a few of my favorite mods do not have a driver, but 1)the xpe2 can not handle direct drive, 2)the UF-1405 has two batteries in series, the led will not survive direct drive, you need a buck driver or use one dummy battery, 3)there are great drivers now, finetuned by BLF-members, that direct drive the led as if they were not there, but do add convenient lower modes by using PWM.
Hi!
since my DMM is good again (tripped the 10A fuse with my 12 XM-L2 project) i gave the 1405 some time…
i put a R100 on the R120 and got from 0,85A to 2,2 A with black 5200 mAh Keeppower
everyting else is stock (the XP-G2 on noctigon is on the way to swap in)
my Luxmeter gives me around 77 kCd - could that be true?
my HD2010 (4,4A with a BLF17DD and dedomed XM-L2) gives 100 kCd in the same setup…
Sounds a bit low to me. I measured 58kcd with stock 1405. Could it be the LED was overheated? What was your measuring distance?
distance was 1m on both lights (lens to meter)…
heat - maybe…
LED is still stock with dome / on alu
1m is too close for both those lights. Measure lux at a further distance and convert it to 1m by lux*m*m.
1m is too short I’m afraid. I always use 4.5m of distance and that might still be insufficient for certain lights.
thank you
I will try…
I was told that also many times, so I started measuring at longer distances (standard at 5m now), but for an aspheric light that did not give significant different numbers from measuring at 1 meter.
I guess I can’t focus the beam right at infinity. My readings still converge to higher lux numbers from 1-10m without altering the focus.
i am facing a problem with the driver i have modded it with a resistor equal to R010 and i was getting 2.6 at the tail cap reading with a XP-G2
and suddenly the flashlight stopped working and then i found a component on the driver fryed, pics will tell, it is the component that the ( - ) to led wire is connected to it and there is another one beside it with the same name but it looks nothing happened to it
the one on the is the damaged one
so any solution ? what is this component ? and can i replace it ? if no any other driver ?
looks like it desoldered itself due to too much current :wink:
i would try to resolder that ripped off thingie (Transistor?)
it cracked and opened in half not just desoldered and i smelled burning , look at the 1st pic
well as i cant fix this driver and i know i cant find a 17mm driver that can take 2 cells in series so i will trim the bill and flat it then i will try to use a 26mm driver something like this TR-0124B 8.4V but i want a driver with a smaller height so can any one please suggest me a driver with 26mm diameter with a short height and can be modded to 5 or 6A ?
I am using this 17mm LD-40 (or LD-4B as how IOS calls it) in my 1405. This driver delivers about 2.2~2.3A to the LED in stock form. I have replaced the the R100 resistor with two stacked R120 resistors and measured 2.45A at tail - which should be translated into >4.0A to the LED.
It works, but I must say the driver is really pushed to its limit already. The mode changing has became problematic after the resistor-mod, and the light cannot be left on high for more than 4 minutes, otherwise the light will becomes dimmer and dimmer over the time and finally shut off by itself. I thought either the driver or LED was burnt but after a few minutes the light works as normal again. I think the driver cannot handle the heat produced at boosted current like this.
I hope you will finally figure out a way to use a larger buck driver in there, because this is also exactly what I wish to have with my 1405.
I have a similar problem, the modified 1405 I just bought from someone on this forum started smoking as soon as I turned it on and burned up the driver. It was almost a really bad situation as it burned the battery holder and almost burned the battery before I could get them out. I am now gonna rebuild it with a new driver and looking at the LD-4B linked above because it can be used with 2 batteries. I dont really want to cut/ or use a dummy cell as I need the run time of two batteries for my work. However, looking at the LD-4B driver you linked, I noticed it says,” *Suitable for 1-2-3 18650, 16340 or 18350”. Does that mean no 26650? And also since the input voltage is for,” *Input voltage: 3-16V ” could I add an extension and add another battery?
Is your modified 1405 using the stock driver?
Your 1405 situation sounds like a short-circuit to me - a short-circuit which involves two batteries in series, definitely not fun at all. My advice to you is make sure your batteries are still healthy before you use them again, check if they still can be charged without overheating, and see if the batteries still can hold the charge for more then 24 hours without significant drop of resting voltage.
I stacked one R100 resistor on the stock driver and it has killed two of my emitters in a split second due to excessive output voltage - something is not right after the resistor was added. Now I label the stock driver as scrapped part so that I won’t forget and reuse it again. Everyone should be reminded that the stock driver of 1405 is not good for high current application. ohaya and wight have done some test and analysis this thread and it is found not suitable for current boosting. I know some members may have good result with the stock driver anyway but I think there is still certain risk associated with it. And I don’t think LD-4B is good for current boosting either.
To put it simple, we don’t have a reliable and high-current capable 17mm buck driver yet.
26650 has the same voltage as the 18650 (neglect the different chemistry), so yeah you can use two 26650’s with the LD-4B driver without any issue, given that your LD-4B is functioning properly of course. By adding another extension does that mean you will use three batteries? So the input voltage will be 12.6V? If that is the case I believe this is still falling within the specification of the LD-4B thus acceptable, but I have not tried and confirmed this yet so just take my words as a grain of salt.
Messing with lithium batteries especially in series could be a dangerous thing, please be careful with everything you do.
I think it is the stock driver, its the flashlight from here: [SOLD] UniqueFire UF-1405 >400kcd
Ran it less then a minute when it started smoking. Batteries used were 2 almost brand new 18650 EBL 2600 Mah.
Here’s more pictures, maybe someone can tell me what happened from these:
I tested the batteries, one is fine at 4.19 volts, the other one that was in the front is showing 0.0 volts.
