I made the triple one and it worked out fine. Based on that, I also made the quad. Seeing as how I don’t have a lathe or all that fancy equipment, mine isn’t as fancy as the updated diagram.
The Quad makes 2500 lumens with XP-G2 S3 3C emitters. The Triple can make 4040 lumens with XP-L V6 2C emitters. With the Ledil Cute-3 the XP-L doesn’t need to be de-domed, so there’s no tint loss or lumens loss. V5 2D emitters give me ~3800 lumens and V4 3D emitters made ~3300 lumens.
Yes, I have made 3 triples, with the last one having an aluminum sink exactly as pictured. And one Quad, with a more primitive sink but essentially the same as the one pictured.
While I do very much like the X6 with the Quad, the triple is just exceptional! The larger TIR lenses and the style of the lens, it looks awesome and just works.
FET drivers of course, and the best IMR cells I could use. Wights A17DD-S08 is single sided and fits into the X6 like it was made for it.
i have 4 host and they all check out the same size, i was thinking once the sample is done i can send out through out u guys to check to see if it fits your guys lite and see how u like them ?
ok guys the head of the light was dropped off today to my machinist, he will be making me a sample for $35 not to bad since it will take time and lots of precision on this one. this will not be the final price lol
Oh he is also making me a software CD encase down the road we need more :)
Somehow I assumed your 4040 lumen monster was the quad. I’m guessing the quad was only lower because you used XP-G2s, is there some reason not to use XPLs and get more lumens out of the quad??
This heat sink has been refined to better fit the bezel for full contact inside the head with better fitment. Call this one the prototype of the prototype.
I chose XP-G2’s for a few reasons in the Quad. The tint, the reduced heat, longer run time, the optics fit without modification or de-doming the LED’s and I just got new S3 3C emitters while I’m about out of XP-L’s.
3 and 4 at a time get’s downright expensive!
Also, I had an aluminum bar and would prefer copper under the XP-L’s. The triple that is making 4040 has a stack of 20mm copper stars under the 32mm copper Noctigon, all reflowed into one piece. It was the doing of that light that gave me ideas for the full cup design of the quad. And then having to wrap the one you see above with aluminum strips for bezel contact made me redraw it once again. So having built a few, all the short-sightedness has been ironed out for the diagram Nitro is using to have samples made.
Before there is a bunch of confusion....sometimes easy to confuse me :) It may be a good idea to poll what people want....triple or quad. For myself I want the triple.
Sounds good. I have one triple from Richard I love using. I find the novelty of blasting max frequently just wears off and you just choose a lower mode to run continuously when you need run time anyways. Whenever I want to “blast” it though, the higher the better. So I’m leaning towards a quad XPL, hoping for no other good reasons not to Cost is definitely one though, these things get so pricey by the time you are done collecting all the parts, and assuming I dont screw something up and it gets more expensive. But I have to give my X6s a real turbo and a reason for the nice cooling fins!
Well the way i see it is that since I'm working with him on the triple, im going to have him make one for the quad and do a small run on them ? And both will be saved on a cd for the cnc machine and I'll probably have few done in copper
