Test / Review: TrustFire TF26650 5000mAh (Flame)
yeah, which item
I’d expect 500mAh from ebay, not over 5000.
I was really expecting something in the range of 4000mAh for these, but ran them 2x each through my B6 to test.
Here is the purchase from E-Bay:
ORDER DATE
Nov 17, 2014
ORDER TOTAL
US $15.02
Free shipping
View order detailsContact seller
More actions
1 item sold byttmallzone365
2 x Trustfire 26650 3.7v 5000mAh High Quality PCB Protected Rechargeable Battery
( 131179057630 )
Delivered on Sat, Nov 29
Tracking number: Tracking numberLK264726706CN
Batteries test OVER 5000mAh……wow
LOL the last line is what I posted in my purchase note on the item, not from the seller.
My pic at test time:
The seller info is in the thread now.
What does “Please post your more usage experience.” mean?
Thanks for the seller info. On the strength of your post, very tempted to get a couple hoping for a long run time in Yezl Y3 — for night time hiking.
I was wondering if you tried them in a flashlight beside your two discharge/charge in the iMax B6.
[EDIT]
Drew blank when searched for the ebay seller:byttmallzone365 .
[EDIT2]
Your item was delivered … on November 29, 2014.
Long time ago.
The best price now is $16.74.
I’m also a little tempted! BLightSam means to say that the seller is “ttmallzone365”.
@ BLightSam: What discharge currents have you tested at? [I doubt your usage experience will tell us much since you just got them…]
This thread and it's info is over 2 years old. A lot has happened since then, but basically, anything with fire in the name is still not likely to be the best to buy, nor will in necessarily be trustworthy. There are plenty of good cells sold by dealers like Mtn Electronics, (RMM), and Illumination supply, but you won't see Trustfire on their web sites. They are just not good batteries to have faith in, since they are inconsistent and copied so much. Some are even used cells, that had new labels put on. Happens all the time. I try to stick with cells from well known and respected sellers.
Greetings O-L,
Most of the time the “Fire” suffix means ‘danger’, indeed.
However, I personally have not had any of apx 18 total, Trustfire batteries be any less than I expected. Most of them are 14500’s, with 2 - 18650’s and now 2 - 26650’s. They have all done very well, at a reasonable cost.
Buying from seller with good history is a good place to start any purchase.
Cheers,
As above, I just ran at 1.0A discharge, nothing else.
I have/had 2 lights that took the 26650’s. Gave one away at Christmas and still have the one with a head that pivots to a 90-degree angle….
Personally I see little or no difference in brightness between the 18650 Sanyo battery and this 26650.
I would expect it to run much longer with the 26650.
their price is now:
Trustfire 2*26650 3.7v 5000mAh Rechargeable Li-ion Battery PCB Protect Board USA
$15.88
or Best Offer
Free shipping
You could try making an offer…?
November 29th was only 6 weeks ago……
Should have guessed to rid of “by”. Found the seller finally. Price changed a little. Thanks for the tip to get rid of “by”. The problem gave me a pause to wait for the results of others actual “field” test.
Didn’t (Couldn’t) get the battery. Bedsides I am incapable of doing any testing except the one by eyeballs. I leave the real test to more learned members.
Oops, sorry dno36 / BLightSam. I directed my responses backwards! You both understood and answered anyway though. :slight_smile:
@Old-Lumens,
Thanks for the warning about “xxxxFire” batteries. But I consider ‘Trust’ is far better than the ‘Sure’ even though it’s certainly not as good as the name brands. I am considering the Trustfire 26650 because of positive reports from 3daysofdarkness (08/16/2014) and now dno36. Considering this battery basically to check out the 26650 lights, and will be actually used only a couple of times. For that I don’t want to spend a lot of $$$.
I stumbled onto that one, and was actually debating whether to offer $14 or $12. What do you think, $14 or $12?
$12 might be a bit scant, but what the heck, the worst they can say is ‘no’.
If I recall there were a couple of other sellers in the mid-$14 range.
Let us know what you discover.
Also thought $12 might be pushing too far. Bid $14. Let’s see what happens.
Go ahead and bib $12, see if they counter offer.
If they just reject your offer of $12 and there is not counter offer, then try $14.
Does that how Make Offer typically work? I made a bid of $14. ebay says seller’s response may take up to 48 hours. If that’s not accepted, that may be a good excuse for me to forgo the battery altogether for now.
Yes, “make an offer” is like bargaining. Buyer offers a lower price than they want to pay. Seller offers a higher price than they want to pay. Somewhere along the lines of the bargaining / negotiation these prices meet in the middle.
In bazaars in Africa, India or Turkey, bargaining is supposed to be good manners. Maybe I should have offered $12 — to be in good manners. :slight_smile:
“Bargaining” is considered very honorable in the Asian sector….The worst that can happen is that they reject the offer and do not counter-offer. If they counter, you can take it or counter-offer back. Go get ’em!
I made an offer and received a counter on this light:
TrustFire-7-CREE-XM-L-T6-8500LM-LED-Flashlight-2pcs-Rechargeable-26650-Battery
Details about TrustFire 7*CREE XM-L T6 8500LM LED Flashlight + 2pcs Rechargeable 26650 Battery
| Add to watch list
Seller information
ttmallzone365 (98390 )
99.2% Positive feedback
I made an offer adding a third 26650 battery to the deal and they came back $2.40 above my offer. I went back to them at $0.50 less than their counter-offer…….we’ll see what happens
Cheers
