TrustFire TF26650 5000mAh (Flame)
I have tested this battery from two different sources.
/DSC_1065.jpg)
Official specifications:
- Brand: TrustFire
- Model: 26650
- Voltage: 3.7V
- Capacity: 5000mAh (actual 4000mAh)
- Rechargeable Li-ion battery
- Built-in protection circuit
- Great batteries for your flashlight or other devices
- Dimensions: 2.68 in x 1.02 in x 1.02 in (6.8 cm x 2.6 cm x 2.6 cm)
- Weight: 6.38 oz (181 g)
/TrustFire%20TF26650%205000mAh%20(Flame)-info.png)
Notice the difference in weight between the two tested batteries.
The charts are not using the same scale as the 18650 charts, due to the higher capacity of this battery.
/DSC_1063.jpg)
From DX it is the usual envelope.
/DSC_1070.jpg)
/DSC_1066.jpg)
/DSC_1067.jpg)
/DSC_1068.jpg)
/TrustFire%20TF26650%205000mAh%20(Flame)-Capacity.png)
They have slightly different capacity, but not much. With the weight difference I had expected more difference.
/TrustFire%20TF26650%205000mAh%20(Flame)-CapacityTimeHours.png)
/TrustFire%20TF26650%205000mAh%20(Flame)-CapacityTime.png)
/TrustFire%20TF26650%205000mAh%20(Flame)-Energy.png)
/TrustFire%20TF26650%205000mAh%20(Flame)-PowerLoadTime.png)
/TrustFire%20TF26650%205000mAh%20(Flame)-TripCurrent.png)
The two batteries has a different current limit, it is not easy to see on the chart, but one trips at 6.9A the other at 7.6A.
/TrustFire%20TF26650%205000mAh%20(Flame)-Charge.png)
TrustFire TF26650 5000mAh (Flame) Manafont
%20man/DSC_2090.jpg)
- Operating voltage: 3.7V
- Capacity: 5000mAh
- Ultra-high capacity and premium built quality
- Protected to avoid over-charged or over-discharged
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-info.png)
These two batteries did also have a weight difference. They are also slightly longer than the DealExtreme version.
%20man/DSC_2086.jpg)
I did only get one battery per envelope, because I ordered them one at a time.
%20man/DSC_2092.jpg)
%20man/DSC_2093.jpg)
%20man/DSC_2094.jpg)
%20man/DSC_2095.jpg)
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-Capacity.png)
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-CapacityTimeHours.png)
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-CapacityTime.png)
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-Energy.png)
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-PowerLoadTime.png)
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-TripCurrent.png)
%20man/TrustFire%20TF26650%205000mAh%20(Flame)%20man-Charge.png)
Conclusion
This battery has about 30% more capacity than a 18650, but about 100% more volume, without being able to sustain more current drain. But it does keep a higher voltage than any 18650 battery under load.
The battery has less capacity than stated on the cell.
For a cheap battery it is acceptable.
The Manafont version are slightly better than the DealExtreme version, I cannot tell if this is random variations or not.
Notes and links
I have added the battery to the 18650 comparator, this makes it possible to compare voltage at different loads.
