It actually seems like it’s skipping turbo in my last build, because all of the modes were tightly spaced and the highest one was still kind of dim. I’m testing with an XM-L U2 and a laptop pull panasonic.
Please test with the code I linked to above:
- Be sure to set your modes up.
- This uses the old turbo style. I’d leave turbo disabled. (That gives 4 modes.)
- I normally disable voltage monitoring while testing this sort of thing.
From what I can tell that didn’t make any difference. Also, I think it has been skipping moon because I commented it out and that also appears to have no difference in the result. Now I’m just playing around with different combinations of the settings to see what I can get.
Remind me which board revision (version) you are using please. EDIT: nevermind, it’s 20mm v007.
20mm v007
In that case I’m not sure what the problem is.
It should be pretty easy to identify which modes are present or not present by using clearly dissimilar values and/or disabling a bunch of stuff.
I did forget to mention that you’ll need to setup that firmware I linked you to with the :8 divider and Phase Correct PWM.
I’m fairly certain moon mode is a no go, idk why though. I have it working with this code.
At least with these settings, 37 PWM is the lowest it can light up a first-gen XM-L. At 37 you can look straight at it and still see the lines on the die. It needs some tweaking on the mode spacing, but otherwise it is working as designed. There is some buzzing on Medium and High, so hopefully tweaking PWM levels can alleviate that.
I have to run to Home Depot now, I’ll play some more when I get back.
Maybe i’ve got the wrong end of the stick here but I think I know what’s causing the confusion regarding Moon mode.
That version of STAR (probably every version?) requires a soldered star to enable Moon mode, ie. A particular pin on the MCU needs to be connected to ground. It looks to me like that particular pin on this driver is left open/ungrounded. Right?
Obviously seeing as there’s no star available to connect it here you’d have to hard code “moon mode” to be on by default. ie. change the 0 in the following bit of code to 1. That should give you the expected number of modes.
“#ifdef MODE_MOON
if ((PINB & (1 << STAR2_PIN)) == 0) {
modes[mode_cnt] = MODE_MOON;”
Possibly you were seeing a medium mode at some point confusing it with an actual moon mode which caused the confusion? Seems likely since the actual minimum output level is ~37 pwm as you said.
Yeah I was just thinking about the star/pin needing to be grounded. I’ll try that after dinner tonight.
My mistake, I should have known better. I got confused.
Probably nothing but should you have both of these lines commented out?
//#define FAST_PWM_START 255 // Above what output level should we switch from phase correct to fast-PWM?
//#define DUAL_PWM_START 8 // Above what output level should we switch from the alternate PWM output to both PWM outputs? Comment out to disable alternate PWM output
That’s all I saw that looked odd to me. But I’m not the one to ask on these things. Wight, RMM or ToyKeeper , by the way, where’s Comfy?
I don’t have that exact line of code, I have this:
#ifdef MODE_MOON
#ifndef DUAL_PWM_START
#endif
#endif
#endif
It’s not a big deal to me, I would only use 4-modes anyways
//#define DUAL_PWM_START 8 // Above what output level should we switch from the alternate PWM output to both PWM outputs? Comment out to disable alternate PWM outputThat’s all I saw that looked odd to me. But I’m not the one to ask on these things. Wight, RMM or ToyKeeper , by the way, where’s Comfy?
I think they technically should be, but AVRStudio won’t compile it if both are commented out.
As I said before, it’s much easier to work with the older version since you don’t use either of the dual PWM features here.
I also had trouble understanding the code you quoted pilotdog68. I posted about it in post #769 over here: STAR Firmware by JonnyC - Source Code and Explanation
EDIT: so if you go to that post and read the code comments in the example code I posted it should be more easy to understand what that very strangely formatted section of code does. The intention is to allow DUAL_PWM_START to force MOON_MODE on. We need to do that since we can’t turn PWM on with the star because we’re using that star for the secondary PWM output! BUT if someone has commented out MOON_MODE it still won’t get turned on. That’s the intention of that convoluted thing.
In the end, you still just make the same change.
Ah. Makes sense.
Nevertheless, before I read your post I was already working on it using the old version of STAR. Here is my final revison.
All five modes work. The lowest firefly is basically just a novelty, but the other modes are spaced nicely. The PWM is still a bit audible, but it’s faint enough that I’m not sure you would hear it at all once it is inside a light. The only other issue is that some people would prefer the OTC setting be a little faster, it’s about 3 seconds right now.
I don’t have a light to put this in yet, so it’ll probably just go in my tacklebox while I try some of your other designs. I think I’m going to try the 12mm dual-pwm fet driver next.
I’m wondering if the driver modes would still work at the slightly higher 2.4khz or 4.7khz pwm frequencies ( using the 9.6Mhz clock combined with Phase correct / fast and 8x divider combinations)
If you’re up for testing that before you pop this thing in the tackle box that would be awesome!
I’ve been playing around a bit with the 1khz pwm on other drivers and it’s bugging me a bit too much to consider putting it in a light. Visually annoying rather than the sound.
I’m wondering if there is any chance the driver modes would still work at the slightly higher 2.4khz or 4.7khz pwm frequencies ( using the 9.6Mhz clock combined with Phase correct / fast and 8x divider combinations)
Well I just realized my Supfire L5 will fit a 20mm driver, so this one will remain on my desk a bit longer.
I can try it, but I’m not sure I follow what you mean. What settings do you want me to change?
edit: are you talking about changing the low fuse to “0x6a” ?
Ah. Makes sense. Nevertheless, before I read your post I was already working on it using the old version of STAR. Here is my final revison. All five modes work. The lowest firefly is basically just a novelty, but the other modes are spaced nicely. The PWM is still a bit audible, but it’s faint enough that I’m not sure you would hear it at all once it is inside a light. The only other issue is that some people would prefer the OTC setting be a little faster, it’s about 3 seconds right now. ………………………… I don’t have a light to put this in yet, so it’ll probably just go in my tacklebox while I try some of your other designs. I think I’m going to try the 12mm dual-pwm fet driver next.
I’d double check to make sure your firefly mode works on depleted cells. It would be disappointing to try whipping that out to show off to someone and have the LED not light at all.
I’ve been thinking that putting in a hidden firefly mode would be best. That way there is no annoying basically-fully-off mode plunked into your rotation, but you can still bring out firefly to impress folks. With a hidden moon mode (like TheSTAR has) I’d think putting firefly right after moon would be good.
I find 3 seconds totally unacceptable. If cranking it to 250 or so doesn’t get it to around 0.5s I’d consider adding a pulldown resistor stacked on the OTC. LinusHofmann ran into a similar problem and stacked a 220kOhm resistor.
I’m wondering if the driver modes would still work at the slightly higher 2.4khz or 4.7khz pwm frequencies ( using the 9.6Mhz clock combined with Phase correct / fast and 8x divider combinations) If you’re up for testing that before you pop this thing in the tackle box that would be awesome! I’ve been playing around a bit with the 1khz pwm on other drivers and it’s bugging me a bit too much to consider putting it in a light. Visually annoying rather than the sound.
Higher freqs will just compress the modes higher. Notice that the current range of modes is ~40-255. Doubling the freq will compress the modes higher, something like 80-255 for example (I don’t know exactly how much upwards compression to expect).
This is all a function of FET selection. An FET with more ideal properties for this driver would function at higher freq. DTU30N02 does.
