I am going to buy two, and if not good will exercise the eBay money back guarantee. I have 4 of the lights from Fast Tech. Probably will take a couple of months to get the lights.
Jerry
I have to stop I cant keep from buying cheap lights lately………….
I have probably ordered 15+ different lights since sometime in December……… the wifey is not going to be happy hopefully I get to the mail a lot more than she does.
Just ordered one from fasttech. It’s cheap enough that loss isn’t a big concern and I have some lithium primary aa’s that I can use in it rather than risking my rechargeables. Not sure I like the modes or mode memory however so that might mean a driver change eventually.
jerm03, did you order the $2.99 ones off of Ebay? How do they compare to your others? Same Q5 led? Just as bright? Finally, was there any customs issues? They sure harp on it on their Ebay sales page.
I ordered five of these and they were shipped on 1/31/15. It shipped next day as I ordered on the 30th. Looks like it took about a month for them to arrive for Jerry so I’ll anticipate about the same. He also has a thread on this light specifically, that’s how I found out about the $2.99 deal.
Here are my results of testing with various batteries. I like the light.
Cree Super Light AA
Lo Tenergy Premium 5hr 30min
Lo Thunder alk 5hr 12min
Lo Everyready alk 5hr 0min
HI Dura ion-co 1hr 39min
Hi EBL 1hr 33min
Lo EBL 5hr 56min
...along with a slightly thicker O-Ring to take up the extra space:
It turns out to be a perfect fit, and creates a great beam pattern. A decent driver and some high-current 14500s would make this into a crazy-bright pocket light. I installed a Nanjg 101AK; even @ 1.4A using my three-year-old TrustFire cells is very impressive.
Also, how about that annoying keychain nub on the base? No problem there... A dremel, a file, and wrapping up with some rubbing compound clears that up. Now it tailstands! Add a good thick layer of GITD nail polish and you get this:
Great mod, i will order the part to see if i like it better than the stock reflector, do you think the TIR would fit an XP-L?
Can you guys help me out though, i totally failed in opening this light
Am i supposed to screw out the driver to get access to the pill or what?
The driver looks glued in, or is the head able to screw open in to parts?
I can’t see any seam that would indicate that.
The head unscrews from the battery tube and also unscrews in half for access to the emitter. The driver is a simple press-in IIRC. The optic fits an XM-L so an XP-L should fit fine too. You'll probably want to use the XP centering ring instead though.
