Since I ran the test in the OP I converted all my AA mini-mags to LED, or so I thought. Just found one that still has the incandescent bulb. So my plan is to test the Utilitech alkaline, Sunbeam alkaline and also the Walgreens battery (the one that is silver like the energizer). I’ll wait till I see a BOGO on them though cause I’m chea…er, frugal
Come to think of it, I should also test the Energizer and Eneloop rechargeables as well.
Once I get that test done (and the Sipik test) I’ll post the results I get.
Wow! Worse than harbor freights! I didn't expect that. Curious on the Sunbeam alkalines.
I guess with my new hobby charger I can do discharge tests on alkalines, right? I realize I'd have to do it at a low current draw. What current draw is appropriate?
I was a little surprised as well at the results with the Ulitech. My only current reservation with the HFT Thunderbolt is that I noticed last night one of them had leaked in the box and actually had to toss a few of them in the trash. But then I guess that happens with the premium line as well. Though I don’t recall a CVS brand ever leaking. I have the Sunbeam Alkalines in both the ML and the Sipik as I type this. I’ll post as soon as the test is complete.
Fairly impressed with this battery for the price. Not quite as good as the Thunderbolt or CVS but not that far off.
So far the ranking based on run times stacks up like this:
1. Duracell Alkaline - Continuous run time 5:20 (dim 4:50) (cost for test 42 cents per battery)
2. Harbor Freight & Tools Thunderbolt Alkaline - Continuous run time 5:00 (dim at 4:50) (18 cents per battery)
3. CVS Brand Alkaline - Continuous run time 4:58 (dim at 4:20) (25 cents per battery if BOGO)
4. Sunbeam Alkaline - Continuous run time 4:54 (dim at 3:24) (25 cents per battery)
5. Utilitech Alkaline (Lowes store brand) - Continuous run time 3:51 (dim at 3:30) (27 cents per battery at normal store price.)
Not counting the Sunbeam heavy duty as it isn’t in the same ballpark.
I'm starting to do some discharge testing of some "budget" alkalines on my hobby charger. I've decided to test at 0.5A down to 0.8v. I'm discharging a Utilitech alkaline now. I have to pickup some other budget options - at least the Harbor Freight Thunderbolts and some of the dollar store Sunbeams as well as the Panasonics sold at the dollar store.
Ok, I just finished testing a fresh new Sunbeam alkaline at the same 0.5A to 0.80v - 1,125mah. Here is a comparison graph between the Sunbeam and the Utilitech. Sunbeam in the yellowish-orange color and the Utilitech in red.
Sorry, I'm new to logview and learning how to work with the graphs.
Alright, this is quite interesting and I’ve been curious about the capacity of various alkaline batteries. So far we’ve got:
Utilitech = 1025mAh
Harbor Freight Thunderbolt = 1,096mAh
Sunbeam alkaline = 1,125mah
I wonder how that compares to say Energizer or Duracell alkalines? So far the $ store alkalines are leading the pack.
I’ve got Eneloop = 1900mAh and Engergizer rechargeables = 2300 mAh. I know the Eneloops claim up to 2100 recharges, I wonder how many for the Engergizer?
I'm testing a Panasonic Alkaline Plus now (from the same dollar store as the Sunbeams). I've always been curious whether these Panasonics were really any good. I do also have some Energizer Max to test as well. I didn't buy any Duracell - at least not yet. In the future I was also going to order and test the Amazon Basics and the Maxell's. I have some AAA Maxells I've been using which seem ok.
Looking forward to the results. I like to get the best “bang for the buck”. I have not been able to determine the best in AAA size. In my limited testing the AA Duracell has shown up best against a couple of others.
Super Light Hi AA
Thunderbolt 2hr 46min 2nd run 3hr 26min
Duracell 6hr 30min 2nd run 5hr 45min
Energizer 4hr 20min
Panasonic Alkaline Plus = 1,253mAh (not surprising to me that it's the best so far). It hold voltage much better too. Graph:
These are the Panasonic batteries (made in Indonesia) and Sunbeams (made in China):
I always look for the "2+1 free" packs of the Panasonics. Sometimes they are hidden behind the standard 2 packs.
I don't want to start the Energizer test just in case it goes beyond the time I have to leave work. I should get to that one tomorrow.
jerm's data brings up a good point; I'm not testing for consistency. Perhaps I had one good performing Sunbeam and the other 3 in the pack are junk. Not sure of the likelihood of that.
Yeah, I was thinking I should do that too. They have usually been my "goto" for a Duracell / Energizer budget comparable. I'll have to pick some up though.
Here are my results for AAA alkalines.
Tank 007 e09 Hi
Thunderbolt 1hr 29 min
Energizer 1hr 58min
Ray O Vac 1hr 39min
I did not have a Duracell, but I got some and have it running now.
ADDED: I finished running a Duracell, and it is disappointing. It only lasted 1he 17 min. Expiration date is 2021.
Ok, Energizer "Max" =1,316mAh HOWEVER, the Panasonic holds a higher voltage. (Energizer gave 7 minutes more runtime over the Panasonic.) Graph comparison:
(Sorry if the above image is not appearing, I'm out of Photobucket bandwidth and it will reset on the 24th of the month (I believe).)
WOW! Just blew the rest out of the water! Duracell "with Duralock" = 1,799mAh! 3hrs 34mins runtime (Energizer was 2hrs 36mins). Duracell has higher voltage than both Panasonic and Energizer. Graph comparison:
