You can compare it to a C8 with an XR-E Q5 in it because it's an MRV clone and they use the same exact reflector as a C8.
Very impressive, if it out throws the skyline. Might have to get me one, since I’m in want of a good thrower . I like the MRV style as well. Do they offer a R2 version?
That beamshot in the ebay photo looks to be of an aspheric in throw mode. The square emitter hotspot gives it away.
Yours would still be a good thrower as I briefly had a C8 with an XR-E Q5 in it and it dies throw a fine beam. Upgrade that with an R2 driven at 1.4A and you would have an awesome thrower!
wow 400 yards that's a long distance! The brightest light i own now is the KD C8 which throws 100 usable yards at most i think. But then it also has a very decent flow and a wide hotspot.
Ok I take that back on the seller. I bought it from this seller.
I thought that square was a target matter, not shure now. But the spill is definitely bright for an aspheric in throw mode?
You are right about the spill, I hadn’t thought about that but the right & bottom edges of the hotspot appear to be on a flat wall while the top & left edges are definitely on the building edges.
This was right at 12ft. UltraOK Technology Q5(400 lumens) on left and Skyline I(300 lumens) on right.
I don't have a multimeter yet.
And I paid $13.99 with free shipping for the light.
Here's a beamshot at 40yds.
Here's 60yds.
And just so you guys know that I know what 400yds is, here's the barn I lit up early this morning while it was dark.
Here's a good picture of the reflector and how it completely surrounds the led housing.
And here's the same exact beam shot picture as above but with the Skyline I. Camera settings are proibably different though and this one is more focused. But you can get the idea that both are throwers.
What about hotspot diameter?
Don't want to be pest, but I already have an HS-802 with a 10cm hotspot at 3m, and if this one is equally small it would be redundant to me.
On the other hand, I like that body (looks the same as my TrustFire F15) and it might work well with an R5 emitter, which would throw a wider spot.
All well,but 400 lumens for Q5 this fantasy,Interesting how much indeed
Give me a sec.
At a distance of 3ft, the hotspot on each:
UltraOK Technology Cree Q5 is 2 and 7/8"
Solarforce Skyline I is 2"
That was manufacturer rated.
It's still a very bright flashlight.
Real there 230-240 lumens. Regrettably,disease of exaggeration cureless beside chinese seller.))Do Not think that manufacturer can indicate such improbable data
