Yes, I have put in a order for it and it will probably be here in about a week, then I need to do a lot of charge curves to test it. This means that the earliest time I can have any review ready will be in two weeks, but that is probably to optimistic (I might need to do some flashlight reviews before I can do the charger test).
I.e. I will probably not be the first to review it, but I might be able to answer some questions about it in a little more than one week, when I have done the first charge curve.
No prob, take your time ;) Those charging curves are very informative and useful (at least for me) :) can tell many things about charger ;) Perhaps you will not be the first one, but I'm sure you'll be the first one with those charging curves.
Wow this is sure going to be a must have.........looks robust and should last a long time, hope they did not skimp on the plastic, and the spring on the terminals just dont pop off.
Are there any pictures available showing C or 26650 batteries on it?
It states on the back label it charges them, but I am not 100% they will fit in diameter, it looks like they might collide with the side walls that sepparate the channels.
Features:
Can charge 4 batteries simultaneously
Four independent Charging Slots can charge batteries independently
Automatically identify Li-ion batteries and Ni-MH/Ni-Cd rechargeable batteries
Have three charging modes (CC, CV and Trickle Charge)
Can automatically detect battery status and select the appropriate voltage and charge mode
3 LED displays charging progress
Stop charging automatically when it is complete
Features Anti-polarity protection
Good heat dissipation design
All chargers are certified by both ROHS and CE
I think I will wait till prices settle down and more shops have it available, and only in case I can see it finally can charge 26650/C with room enough and not using magnets, aligator clips etc.
