Really dig these illuminated tail switches and I bet they will see widespread use. Is anyone planning on integrating the driver leak resistor into new driver designs? The original thread is good for a laugh since so many people said it was not possible.
Dunno if it’s any help, but I recently spent quite a while searching digikey to find the smallest dip switches. The smallest I could find were about .250” x .140” and .120” tall and are: 1 position, 25mA, 24VDC, SPST, with recessed slider and gullwing contacts.
“dip switch in series with the leak resistor” - that would make it more driver dependable - there are drivers with some leakage current on their own - you would only shut up the resistor part. The switch should be better placed at (in) the tailcap (and is better accessible there).
If I understood the idea correctly, this would also make sense in some lights with lockout possibility. This would just disable the standby signal light and still have the light ready to use and not potentially about to spontaneously fall apart. Using tailcap lockout is sort of the same as removing batteries and storing them in a separate case, excuse my exaggeration here.
Agreed. As this sort of locator light circuit goes through both the driver and tailcap boards, and some drivers may be ready to use in stock config, it makes sense to put any hypothetical switch in the tailcap. Also the accessibility issue would be kinda critical on some hosts. The tailcap is most of the time easily accessible vs. the driver board or other front contact board that often is not.
Just had my first go at making one of these 17mm single led version for now will give the 20mm version a go later in the week.
120 ohm bleeder on driver and two 10k ohm parallel on the tail.
I never tried a GITD boot, mainly because I don’t really want to . Part of my motivation for doing this was so that I wouldn’t have to use those green switch boots anymore. :Sp
At least from my short experimentation on adding diodes in series, it doesn’t appear to work as I/we had hoped. It seems to act like a 2nd limiting resistor, so as the battery volatage goes down, to led gets dimmer and dimmer. It doesn’t just shut off abruptly when the battery drops below a certain voltage. However, it is very obvious to see the effect, so you can somewhat judge the charge level of your battery by how bright the tail led is. On my S8, it is set up so the led is almost invisible once the battery reaches 3.1v, and completely stops drawing current between 2.9 and 3v.
Also, the little dip switches I ordered were delivered yesterday, so I’m going to see soon if they are small enough to add to the board.
Completed my first one today after picking up some 560 ohm resistors from Radio Shack. I went with 2 blue LED’s and a 6.8k limiting resistor. It measures less than .25mA so nice and efficient. I might put a lower value in to up the brightness a bit, it’s not a bedside light so I think I’d appreciate it just a bit brighter. This went on my 1504 with the reduced nubs with an XP-G2 S3 3C measured at 3.3 amps at the tail. The picture is a pretty good representation of the brightness in a dark room.
I’d also like to note that I used the 6A forward clicky Ebay switch for this. It fits once you bend the legs underneath the switch to solder to the board.
I had to turn about 1/4” off the base of the aluminum threaded retaining ring to get it to seat down far enough when assembled. I added a jumper wire and soldered the spring and jumper directly to the brass button.
