The Deft X of poor guy *UPDATE* 04/19 Attache beamshots #48
This is zoomie. Would like to see how it looks zoomed out.
Very nice build! You broke world record in this size :)
Thanks for the write up gaston01 :slight_smile: i am glad i asked :wink:
I wish for one thing now……….to see a 1000kcd or more beam with my own eyes, beamshots just does not come close to scratch that itch :smiley:
What lens & XP-G2 bin did you use? I know it was an 78mm but where did you buy it?
And have you thought of adding a bigger diameter meniscus lens as a final lens as MEM found, to up the kcd even more.
Nice! 8) I want to see some cloud bouncing beamshots!!! :party:
Great throw, well done. To get 1350kcd throw with a 80mm lens you have done everything well: quality led, quality lens and very good performing collar. I'm as well curious about how you made the collar (or was it bought as is?)
I think he used one of waviern’s collars.
Djozz if you haven’t checked out Linus thread gaston01 mentions in the OP you should. Lots of very interesting discussions about collars & various ways to optimize an aspheric build :wink:
Thanks you guys for all the comments :slight_smile:
I buy the wavien collar here: http://www.wavien.com/shop/rlt-collar/
Yes in darkness the PVC give some usable spills but to walk, I open the zoom and is converted to very good flood, I’ll take some pictures of it and upload ….and a mid-zoom shooting a stream of impressive light!
The led are from Fasttech Xpg2 R5 1A on Aluminum star then I reflow on sinkpad, the lens are 78mm from Kaidomain I buy 2, one goes good the other not :frowning:
As I said, the secret is in the focus on collar height, the thickness of aluminium coke can may mean 1100 or 1200 KCDS ….
Very impressive build , sir .
Thanks for sharing .
The future just showed up! Great light! If only there was a BLF edition. Hey, a guy can dream can’t he?
What can i say, omg throw! By the way, do you
Think this will work in a sky ray king body?
The time has come for 1mcd 50$ lights :smiley:
I had ignored that thread at first and then it got too big . I will dive into it one of these days!
To say this is impressive is an understatement. You have done a great job there!!
I think you are going to like what you will find :wink: I remember thinking i wonder where djozz is, this discussion is very much up his alley :slight_smile:
I'm a bit on a flashaholic ration at the moment (my girlfriend is getting annoyed lately about the time I spend hobbying and she is right), but at least reading BLF is not as disruptive for family life as hands-on testing/modding in my hobby-corner.
Orsm light. The workmanship and effort put into this light is amazing. Thanks for sharing.
Can you explain to me why the collar is as large as it is? Couldn’t it be just slightly larger than the LED? The distance from reflector to LED is the same as the distance back to the LED so the aim should be the same even though a smaller reflector’s angles would be wider. It also seems a larger reflective surface would need to be more precisely smoothed and positioned.
BTW, very impressive work and thanks for sharing.
OMG, Gaston! That is simply amazing! I had to read the throw figures 3 times before I was sure I was seeing one MILLION three hundred and fifty THOUSAND candela. Good lord! What a fantastic job! You didn't just build your own Deft X, you smashed it into the ground and doubled it's throw. Mighty impressive work.
1.3Mcd!
We’re talking about over 2km of throw! :open_mouth:
Santo cielos! Es un láser de color blanco. Del dicho al hecho hay muuucho trecho! pero no lograste, huevón lo superaste! Ya el foco tuyo es el cima. Quedo buenísimo.
Nice work, and very impressive figures you’re seeing.
I would like to see verification of those figures measured at greater than 6meters though.
Call me skeptical but I consistently see artificially higher candela figures when taking measurements below 10 meters. The beam isn’t really formed yet at that range (provided the focus is set for maximum throw) so I’d be really interested in seeing what kind of difference in throw (if any) you get when measuring at longer ranges i.e >50meters.
Oh and if you’re not happy with the look of that plumbing pipe, have you thought about finding and combining some cheap lens hoods/filter rings on ebay that will fit that 78mm lens? It’s a good size lens for that kind of approach! :slight_smile:
Keep up the great work
Cheers
Linus
