Chibi, even my Core Ti is modified! I bought a nice translucent white opal and inset a purple trit in it, used this to replace the stock button. And I’ve replaced the emitter with a Nichia. My Ti HF has a hand made and polished Ti reflector and my CU HF now has a 219 Nichia. The Ti HF with zoom head has an XP-L V6 2C.
I don’t have an MM15 or ZB S6330 nor have I even seen one of those.
Is ANYTHING really in the same category as this light? The extensive design implementation with copper top and bottom, thick 3 Oz. traces and that remarkable boost driver with it’s complicated UI is pretty over the top.
And I’ll say it again, the rules say you cannot use white in anodizing aluminum! The die particles are simply too large to fit into the nano-tubes opened in the surface by the anodization process. So how did they get “Stone White” in type III hard anodize?
Yep that is so, the answer should be, it is a commercial name for a light grey, the light it is clearly not white in the true sense of the word, stone also kind of denotes that the white is not white. All photos I have seen so far clearly show light grey not what is considered white.
To me that looks more like what I’ve often heard called “natural” anodized. I have a couple of lights with that finish and its not really white, but rather light grey.
I weighed them all on the same scale, without batteries (batteries will add the same amount of weight in all three, since they all take 4x18650):
M6: 15.4 oz; 437 grams
MM15: 12.1 oz; 343 grams
M43: 12.9 oz; 366 grams
Of note, the MM15 is a bit lighter, but it doesn't have nearly as much copper inside.
The illuminated button. It indicates the battery charge depending on the color. It can be set to be constant on, beacon (flashes intermittently), or can be turned off. This one is much less annoying than the MM15 beacon, which I feel is far too bright.
A few more colors:
The moonlight level is pretty low, considering you are powering 12 emitters. The switch light is always on when the light is turned on, and shows the charge level, as well as indicating mode changes and thermal regulation.
The machining and anodization are first-class, and very consistent throughout the light.
Did I mention that the square cut threads and anodization are first-class?
The tailcap has a nice laser-etched logo. I like that the rest of the light is clean.
Yes, even the spring holder is a copper MCPCB. The screw holes are countersunk.
The other side of that tailcap MCPCB. Here you can see the Beryllium-copper low-resistance springs.
Here is the battery contact side of the driver. The contact surface is thick and shouldn't wear quickly. I didn't take this one apart, since it's my only sample and it is going to be sent to several others for review. There are some pictures of the driver available earlier in this thread.
Here you can see the AR coating's reflection. I can't see any color cast in the LED output, and under most viewing conditions the glass is virtually transparent.
The light thermally regulates and keeps the maximum temperature around 50C on turbo.
This is definitely not a budget light; instead, it is a premium light that is going to duke it out with the best and most expensive the industry has to offer.
pilotdog68, if you use PayPal Credit you get 6 months zero interest. Entry level on this light means you could make 4 monthly payments of $40 (a measely $10 a week) and own the thing outright without ever incurring interest.
Unknown, Sinner will tell you the easy answer there is buy em both.
The knurling looks exceptional on this light, I wish they were all like this. I love small lights that think big, seeming very much like I’m going to LOVE this light!
Edit: pd68, it’s not A light, it’s 4 triples at just over $30 each. Think of it as 4 triples at $30 plus a little extra for the holster and fine packaging.
Well when you put it that way I guess I’ll have to order one. I really wish they were dedomed V6 3C XP-L’s though. If they were I would have already ordered one.
My thoughts? Even though this is a statement against interest, I think that you are smart not to buy the light. For most of us, these lights are toys, and therefore a want and not a need. You should never buy a want on credit. If you can't pay cash, or even if you have cash if you have to worry one bit about the money spent, then you shouldn't buy the flashlight.
Haha maybe not as much as some people! I have lights worth more than that now, they just didn’t come from the factory that way. Even so, I think my most ‘valuable’ light is my X6 Triple that I have roughly $70 in.
Richard sounds like a wise old man in here :face_with_monocle: . Between his and my wife’s “advice” this won’t be on my shelf unless I get a significant, unexpected promotion at work.
It’s an amazing light though, i envy those of you with the ability to purchase one.
LOL… I guess I have too many “wants” than need :weary:
There’s so many times I said to myself… OK this is it… this will be the last light I buy, then again there’s always a GB and always a new and better light not too mention new LEDs :weary:
Maybe I should stop with this light
I’m wondering what it’d take to chop it down for 18350’s, :bigsmile: how LOW can you go?
Don’t know if they could run it but it’d sure be neat looking as all get out! (well, ok, I know they could because I have 6 Efest Purple 18350’s running a triple XHP-70 which is, essentially, 12 XM-L’s right? This is the light making 14,455 lumens.)
Edit: See, you’re not a true flashaholic! He would also add his signature for another $50, add some trits, bump the amperage, change optics on the triples and get the price up over $400. SOME people don’t buy a light that cost’s LESS than that…
Dammit you guys, my wife is going to kill me ! I thought I would be able to resist this one. Ordered the dedomed xpg2, thanks for the commentary on the benift/cost of dedoming with this light Djozz and the photos of the backlit button Richard, that was the last straw indeed.
