Judged moved my first led tail cap to a solarforce containing this driver and it lights up with out a bleeder resistor. I see what was ment by some drivers having their own leakage.
I just tried purple led’s and im a little bummed. According to the Vf rating, they should work just like the blue ones do, but no such luck. They don’t produce enough usable light until they get over 3.8v
Has anyone tried this mod on a light with a Q.lite rev A driver with mode memory and an off time cap? I just noticed that this mod appears to make the light next mode memory, I assume because the cap can never discharge. Am I on the right track? If so, do we have any other options, or will this effect be present on any driver that has off-time mode memory?
Did you solder a resistor across the driver? (560 ohm or so , from + to - )
Yup, that’s why I’m thinking it’s the off-time cap being affected.
Just checked, it turns a BLF17DD into next mode memory too.
Try a lower resistance on the driver.
I was having the same problem, but 560ohm worked for me. You may have to go lower though.
You mean a higher value? It’s using a 560 ohm currently.
No, lower value.
Does that cause the caps to drain faster then? Just trying to understand what’s at play causing it.
I’m driving so I can’t really explain right now. Have a look at the original thread linked in the op.
Will do, it must be something I forgot reading from the first time I looked through it. Thanks for the help, drive safe.
Odd... seems like there is still too much voltage drop across the driver. What values are you using for the resistors and what color LED (forward voltage drop)? Is there a diode in series with the LED (if not try adding one)?
Maybe try using an Off Time resistor (across the OTC)? This may alter the OTC values in firmware...
2 red LED’s with a 1.8-2.2 Vf, 1k limiting resistor, 560 ohm across driver, bridged diode pads on board for 3rd spot
2 LED version of the board
Your comment about voltage drop across the driver just rattled something loose in my brain. A lower value resistor on the driver will drop more voltage, which probably let’s the driver see a voltage too low to run. When the value is too high it’s sees a voltage too close to its operating voltage, so the driver memory must never set.
That is my educated guess without following Pilotdog68’s advice and re-reading the other thread yet(which I will do).
Hmm something seems off. Those red leds should be much brighter with only a 1k.
Your theory lines up with my own. I don’t think the issue is just the OTC not draining, I think it the entire driver is getting enough power to stay awake, so memory never sets in. (I’m pretty sure that’s what you said)
I don’t know all the electrical lingo and my circuit understanding is still pretty basic, so I’m just going off what I observed. The test with the blinking LED revealed a lot.
Are the LED’s in series or parallel on the dual LED board? I’ll test the current draw with my DMM, but it wasn’t even registering 1mA on my power supply.
The LED’s are parallel to each other, and in series with both D1 and R1.
I was reading through the other thread just now, and post #86 is a good one to start at. That’s what I believe is happening to you, but a lower resistor on the driver should remedy it.
Pilotdog68 = my hero
Thanks for the help, I’ll update once I get it all sorted out.
Results are in. Modes work again. Here was what I did.
1) changed current limiting resistor to 470 ohms to increase brightness as requested by slow2go
2) changed to a 330 ohm resistor on the driver, no mode memory
2) added a 1N4148 diode to the board to see if I could reduce leakage to the driver, no change
3) dropped resistor value on driver to 100 ohms, MODES WORK, draws 2.9mA
4) dropped resistor value to 220 ohms for current limiting resistor to further increase brightness, mode memory stopped working
5) changed the resistor on the driver to 51 ohms, works properly again.
Based on my findings I think the ratio will need to be about 5 to 1 for the resistors (limiting resistor on board about 5x the value of the one on the driver).
I love a good challenge.
