New XP-L High Intensity Emitter
Yeah, but if he’s friends with someone in R&D… :bigsmile:
Was that bose301s?
pct.cree.com lists XP-L HI V3
so here we go:
@ 3000 mA, Tj = 25°C
XM-L2 U4 : ~ 1282 lm
XP-L HD V6: 1251 lm
XP-L HI V3: 1095 lm
Or, look at it another way. At bin V3 on both XP-L HD and the new HI, they are exactly the same at every current level, so both are 1095 lm at 3A current. The difference is that the XP-L HI doesn’t have the higher bins. Okay, maybe those will come in time. Looking at the difference from XM-L2, though, it seems we’re going backwards. The closest bin level to being comparable to the XP-L bin V3 is the XM-L2 bin U2. At 3A current, it gives almost 30 lumens more, and the Vf is 3.43V compared to XP-L Vf 3.46V. Then, you have two more bin levels, compared to the XP-L HD having four more bin levels, and still can’t reach the max lumens of the XM-L2. So, the XM-L2 puts out more lumens/watt than the XP-L emitters. Why? Aren’t they supposed to be the same die?
I know they are exactly the same at every current level, just wanted to let people know that there’s a V3 already listed, because in the datasheet there was V2 as the highest flux-bin for the HI version.
As for the XP-L vs XM-L2 comparison, try to look at the XP-L not as a replacement of the XM-L2. It’s a different LED that can fit in places where the XM-L2 can’t. For example the 32XP noctigon board combined with LEDIL optics is a winner. Now with the XP-L HI, you can probably fit them under carclo optics without having to modify anything.
Again, the XM-L2 isn’t replaced, they still come up with higher flux-bins, now U4! I think those are only good news.
With dedoming, you always have a loss of total lumen output, tint shift, possibility of damaging, possibilty of ripping off some of the phosphor and if everything goes right, you end up with a much more fragile LED (if not resealed). Never been a fan of dedoming because of the above mentioned reasons. With the XP-L HI you have less output as well, because of the lower bins, but you’d get less output by dedoming anyways. According to the datasheet, the HI version gives a 120% increase in lux over the HD version using the same secondary optics, if that’s true, than this is more than I’ver ever seen someone achieved by just dedoming.
In a few months, you’ll find M2X Javelot competitors all over the place. Imagine the M25C2 Turbo with a XP-L HI…
Imagine all those sub 30$ lights that will do 100+ klux in stock form.
As mentioned before in this thread, this changes everything!
That M25C2 Turbo looks crazy, to bad its crazy expensive also, i hope some Chinese budget light maker clone that 92mm head with a single 18650, for an more affordable version :wink:
@ cajampa
exactly, that thing is a beast but it’s damn expensive. We need more lights of this type, but cheaper and with XP-L HI :wink:
I need four of these now. I wonder would they handle 5 amps each in my quad-DST thrower project.
Did they just put a clip on that light?
LOL :smiley: yes you are right, i didn’t even see that clip.
Who would ever walk around with something, as crazy wide as the M25C2 Turbo clipped to their pants or belt :smiley: i just cant see that happening.
If someone buys it please try it out & post a picture :smiley:
Thanks for the laugh this morning Ronin42 :wink:
There's a belt clip on it..
Looks like a Sipik with an expensive telephoto lens on the end..
I think it’s mainly because the M25C2 is just a bigger head version of the G25C2, anyways, thanks for pointing out the ridiculousness of it, made me laugh.
I’m fairly sure there are at least a few Cree employees lurking here - I’ve spoken to one of them that I randomly ran into at a bar. I know of one fairly regular poster who works (or worked?) there (never met him in person). Cree is based in the area where I live, so I have some very minor connections (my parents are neighbors/friends with one of the executives - before you ask, I have zero pull. Believe me, I’ve tried.).
It’s probably a decent guess that some of the folks with Raleigh/Durham/Cary/Apex NC in their Location could potentially work for Cree. I can’t imagine there’d be that many flashaholics in one town that don’t in some way work in the industry. I’m an outlier — I work in commercial real estate.
But yeah, fairly safe assumption that some of the folks there are at least aware of BLF.
Which of those is 2200k+/-?
Hey @RMM will you be the first to supply these new XPLs?
Does Cree even have a tint bin for that? Tints starting with ‘9’ or ‘10’, perhaps?
/me looks at the data sheets…
Okay, they have a special group of extra-yellow tint bins… so you want an AA3 bin? That sounds painful to look at. Anything warmer than ~3500K makes my eyes bug out.
Anything warmer than 4000k makes me order replacement emitters like there’s no tomorrow…
Lol 2200k was way off. Was meaning something Warm. 3000k-3200k
I’ll take your warm emitters if you ain’t want’n them :slight_smile:
(Seriously)
Yeah? I’ll start shipping you all my 2700k incan light bulbs.
I’ll take em!!!
