I’m tempted by the monster output in a tiny light, but the UI would drive me crazy, so I have no plans of buying this one. That’s good news for my wallet!
Kind of all other LEDs fail comapred to the Nichia 92CRI tint.
But it looks like your images are too saturated overall. I mean looking at the room image with the painting I can see heavy blue on the walls, which seems exaggerated and there are some color casts around there too, like the yellow color that it is in the top side.
It’s not white, it’s a hard anodized natural finish aluminum that looks bead blasted maybe? And it’s freaking gorgeous! The XP-L2 S4 2B emitter puts out white light. White. Not blue/white, not green hued, not orange or brown or rose or…… white. PERFECT!
Absolutely LOVE IT!
Very fast shipping, stoked on this overall deal. Thank You Thank You Thank You! (to everyone even remotely involved in making this happen)
Ok now I am even more excited for my stone white meteor. I’d love to see a photo, as it seems every review involves dark grey meteors and other than the pics on Hanks site, I haven’t seen a white one. I’d love to see more photos, as I am sure shipping will take another week or two for me here in Canada.
mhanlen, after seeing your review it would be a crime of capitialism if they did not send you one gratis (after they get caught up with demand of course) oh and BTW did they get officially “overwhelmed with demand before or after your review came out?”
um, guys…. there’s something wrong here. Didn’t Hank say the XP-G2 S4 2B made like 6900 lumens? Actually it says it right on the box. BUT, I just got a 23,100 meter reading in my light box, which translates out to 7,969.5 lumens! 4 new Efest Purple 35A button tops on board. Rested, not even freshly charged.
The box says it’s XP-G2 S4 2B at 5700K, and that’s what the beam tint looks like to me as well. Interesting. Surprising. Very pleasantly so…
It Allows, Lantern loves calibrated in Turbo, just remember that, Strange Behavior, Periodically Crawls, ate much food, audible beep periodically slips, a smooth appearance and disappearance - a normal situation, but sooner or later begin to operate in the supervisor microcontroller hardware throwing program voltage, fear strikes the back of the lamp, Lantern evaluate the possibility of such batteries and allows . Pay attention to him, and not on the maximum current stated by the manufacturer of the battery
This sentence sounds like somthing from Alice in wonderland, “Neat ate an audible beep periodically slips with a smooth appearance and disappearance - a normal situation.” What exactly does that mean?
Appearently the lamp is designed for batteries (read protected) that are not powerful enough for the lamp?
From #521
14 quick clicks + clamping calibrates the sensor. During calibration, temperature sensor temperature torch body must be leveled room temperature (25 ° C). The program allows the deviation of the temperature sensor from the typical value at ± 16 ° C. Successful calibration is accompanied by a double flash lamp and a green flash backlight button. If the temperature sensor readings are outside the allowed values - the rejection of the calibration will be accompanied by a single flash lamp and flash the red button illumination.
Lantern loves calibrated in Turbo, just remember that. Prolonged operation at low currents can upset the model due to the low quality of incoming information that will lead to strange behavior when trying to rapidly enable maximum power. Due to extremely low native resolution PWM is used in the M43 microcontroller (5 bits) density-pulse-width expansion periodically crawls in the audible range, and the lantern may occasionally ate much food on the high frequency, Repeated attempts are allowed it to include, but sooner or later begin to operate in the supervisor microcontroller hardware throwing program voltage of about 2,7V. Below this value, the battery discharge does not happen.
The design of the lamp is designed for protected batteries, so to have to stretch the spring force, and fear strikes the back of the lamp, which is why the batteries their weight can spring back to its original state.
The problem with protected batteries is that they are not powerful enough for the lamp, so it makes sense to refine power cells themselves. However, not all require the maximum brightness. Weak batteries have a high capacity(currently 3400mAh, against 2000 in … 2500mAh power) and allow a half-fold increase in working hours* flashlight to frequently used modes. Lantern evaluate the possibility of such batteries and allows the use of a turbo without overloading it, so the use of weak batteries is allowed and does not lead to unreliable operation. And unlike they often have power and protection, and button-top.
The program evaluates the load carrying capacity of its battery internal resistance, allowing the voltage dips in all chains (including spring lamp housing, contacts, etc.) to 0,5V. Resistance chains of the lamp, according to the terminal (see. “Terminal Mode”), about 4 mOhm, and the maximum supply current - 30A. Accordingly, the maximum internal resistance of the battery - (0.5V / 30A-0,004) * 4 = 0.05 Ohm. That this option is important when choosing batteries. Pay attention to him, and not on the maximum current stated by the manufacturer of the battery. This market value is not always the reality. Especially at Panasonic.
The overall efficiency of the inverter, as well as the amount of capacity to effectively use the battery depends on the discharge characteristics of the battery. Choose batteries with the highest average voltage (3,7V and above), as at higher voltages, the driver operates efficiently.
Ok based on post #521. Meteor M43 is not the type or model of lamp but must be “His” name! Maybe he thinks he’s a god?
so it looks like Meteor likes up to 30A cells but will reward greater mAh with longer run times. And it also seems He is a bit conflicted about eating protected cells or not?
and we should pay attention to his preferences “maximum supply current – 30A. Accordingly, the maximum internal resistance of the battery – (0.5V / 30A-0,004) * 4 = 0.05 Ohm”
“The design of the lamp is designed for protected batteries, so to have to stretch the spring force, and fear strikes the back of the lamp, which is why the batteries their weight can spring back to its original state.
The problem with protected batteries is that they are not powerful enough for the lamp, so it makes sense to refine power cells themselves. However, not all require the maximum brightness. Weak batteries have a high capacity *(currently 3400mAh, against 2000 in … 2500mAh power) and allow a half-fold increase in working hours flashlight to frequently used modes. Lantern evaluate the possibility of such batteries and allows the use of a turbo without overloading it, so the use of weak batteries is allowed and does not lead to unreliable operation. And unlike they often have power and protection, and button-top.
The program evaluates the load carrying capacity of its battery internal resistance, allowing the voltage dips in all chains (including spring lamp housing, contacts, etc.) to 0,5V. Resistance chains of the lamp, according to the terminal (see. “Terminal Mode”), about 4 mOhm, and the maximum supply current – 30A. Accordingly, the maximum internal resistance of the battery – (0.5V / 30A-0,004) * 4 = 0.05 Ohm. That this option is important when choosing batteries. Pay attention to him, and not on the maximum current stated by the manufacturer of the battery. This market value is not always the reality. Especially at Panasonic.
The overall efficiency of the inverter, as well as the amount of capacity to effectively use the battery depends on the discharge characteristics of the battery. Choose batteries with the highest average voltage (3,7V and above), as at higher voltages, the driver operates efficiently.”
On that last photo, the stacking effect is pretty clear… I can see exactly where the exposures transition to each other. How close did you have to get the camera to get that much detail? How far open was the aperture to have such a narrow depth of focus?
I think I’d have to get a dark grey model just so it wouldn’t look dirty all the time. White shows every little speck of dust.
