Black Cat AAA
12 posts / 0 new
old4570
Last seen: 3 weeks 4 hours ago
Black Cat AAA
Black Cat
Heatsinking for the LED , I would rate some what poor ...
Take note of the 2 part tail cap ...
Pill makes contact with the middle body for neg contact , so if the pill gets pushed forwards , contact may be lost . Also the middle part of the body holds the pill in place in the head .
Output with a single Alkaline AAA is about 30 Lumen for 0.9A current draw
Output with a 10440 @ 4.08v is =  Starts around 150Lumen , but right away begins to sag , stabilizes around 80 Lumen , but the light is heating up quickly , @ 1.07A  [ Thats over 4Watts ]
 I would suggest great caution for use with 10440 , I noticed far less heat when using a 10440 with 3.8v , and I would suggest that the LED is under great stress with a 10440 ...
Matt
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: sb56637 on 09/06/2010 - 21:54
sb56637
sb56637's picture
Last seen: 21 hours 38 min ago
Thanks Matt for the detailed picture! I fixed the image width for you, if you click on the picture and then on image icon, under the "Appearance" tab you can see how to set the width to 100% and the height stays blank. That way it resizes well.
I do like the knurling a lot on the Black Cat. Looks rather well put together for the price.
old4570
Yes , surprisingly well made : I think the lens might even be glass ..
Very positive tail clicky , and nice and tight on assembly , smooth threads , nothing to complain about except a contact issue with this one that was easily fixed with a bit of file work  .
Thanks for the picture re adjust , ill get the hang of things hopefully ...
agenthex
agenthex's picture
Last seen: 8 years 1 month ago
Mine (5000K red) is 1.9A (!) on nihm. But I'm pretty sure the head is glued. I cannot take it off even using rubber claps.
Reading this makes you smarter: http://lesswrong.com/
Don
Don's picture
Last seen: 1 year 1 month ago
The pill looks pretty much the same as the Tank007 E07
E07 pill p
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
fran82
Last seen: 12 months 2 days ago
Mine with alkalines is 1,3A
Ni-Mh is 1,6A
10440 0,9A
I was thinking to gift the BC, but now that it can use 10440, is another light! about 140 lumens at start!
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
fran82
¿anybody knows how to change the switch and put another in case of failure? I dont know how!
Is glued?
Don
Don's picture
The internals look rather similar to those of the Tank007 E07 which needed a LOT of force to get the glued head apart. See at the bottom of this page on Jayki.
fran82
Yes the driver board and lanyard says "tank 007"
sb56637
sb56637's picture
Don wrote:
 p
Nice forceps Don! Tongue out Might be the first time in history that those have been used to disassemble a flashlight.
Don
Don's picture
Ever since my first set of haemostats (Or locking forceps which is what they get called in operating theatres here) I've used them for all sorts of things - think these ones came from DX. The Tank007 E07 victim here wasn't the first, I tend to reach for those rather than non-locking ones every time. They are also very useful as a heatsink when soldering heat-sensitive stuff.
XRAYBoY
XRAYBoY's picture
Last seen: 2 years 9 months ago
Don wrote:
p
I also use in my work. Here are called as "flat mosquitoes" or Kocher in medical tems.
(and are very useful for welding as Don said or to rescue some lost cable)
ForoLinternas.com
