I am going to pick one of these up at this price - thanks for the short writeup/review
had a few points - came to $7.05 shipped via epost with tracking
Don’t try to burn things without real safety glasses. Not worth it. You may not notice slow, minor damage to your vision but its still happening.
Guys seriously, not worth it at all.
Trust ME! I'm wearing safety glasses! I don't want anything to do with cumulative vision loss due to playing with a toy...
I do know this makes a nice visible beam into the night sky; I'm looking forward to a cloudy night so I can shine a beam in fog, or at least try to make a dot on the clouds...
It burns holes through a 1.1 mil black plastic trash bag, and cuts through a black plastic grocery sack easily.
I agree with HALO, you really need laser safety glasses as the chinese do not have any regulation on these small lasers. you really could do some damage.
which glasses to buy?
Glasses that provide real proper protection cost more than the laser…
Eagle Pair 190-540nm
I’ve seen testing that showed uvex sct-orange glasses offers some protection from 532 green lasers but that was awhile ago. Not certain it still holds true. Uvex sct-orange are not meant as laser glasses. The dyes used might have changed since they were originally tested and it may even change a bit from batch to batch. 532nm green is close to the cut off of what they cover so even a slight change in the dye would be a problem.
I got a pair of ThorLabs pretty cheap and I really like them. they are very comfortable.
Proper 532nm wavelength preventing laser safety goggles is in need.
I get a very special 5mW APC green laser pointer. It just keeps permanent 5mW output power emission in all conditions.
This is a totally safe and class IIIa laser. if output power is higher than 30mW, just be cautious and take safety measures as well. Enjoy the laser fun freely.
I've since bought and received the same laser but in blue from Gearbest. This unit IS a firestarter! But it's fairly scary as well, so use caution! Always wear glasses!
http://www.gearbest.com/led-flashlights/pp_105699.html
This model is slightly shorter than the green model I already have.
When I received this LASER, the beam woudn't focus into a tight spot, so I had to disassemble the head and adjust the lens focus. Now I'm able to get the light focused into a beam att longer distances, while still being able to focus to a closer point for the burning/fire starting. SO WEAR YOUR SAFETY GLASSES!
I was concerned because I couldn't see the dot at first. When I removed my safety glasses though, I could see the large purple blob of light on the wall. Apparently, this light is VERY close to the 400nm UV side of the blue spectrum. Outside, the light creates a deep purple hazy blur when shined against a remote wall. Very little light is visible when using with my UV/blue filtering glasses. The beam is only barely visible in the air, but is interesting when directed onto the trees, as many of the leaves fluoresce a bright red, making blue/red/orange flashes depending on what the beam hits.
This light will make wood smoke and blacken when focused to the smallest possible point. It will burn through paper, and immediately make any black plastic smoke, etching lines across the surface. I inadvertently allowed the beam to hit my hand, and immediately noticed the heat on my skin. After several tries, I was successfully able to get a match to ignite when held in the beam. I was also able to pop a balloon from across the room, while hand-holding the laser. So you had best be wearing your safety glasses!
The green laser is much more impressive due to it's brighter spot and more visible beam. This laser is more dangerous as it's in a more dangerous wavelength, that is also more difficult to judge due to your reduced ability to perceive that portion of the spectrum. So always wear your SAFETY GLASSES!
If you want a blue laser just for the fun-factor, I would recommend you avoid this high-power 301 and purchase this unit instead:
http://www.gearbest.com/led-flashlights/pp_107368.html
It has a much bluer color (True blue, less purple/UV) and a more visible and pronounced spot. For $3.79, it's a good option. Even though it has a much weaker emission, it looks more impressive due to the higher visibility.
They have a red laser there also. Have you ordered that one yet?
I’m a total dummy when it comes to lasers, but if you don’t point it at your face ever, how does it harm your eyes?
Honestly wondering.
hint: the bright dot you see is the reflected light
the more a surface reflects (mirror / chrome) - the less LaZ0rpower is needed to cause damage…
So what about some of the ridiculously bright flashlights we buy/build?
I got a X60vn, it’s 6500 really well focused lumens, the hotspot on turbo is painful to look at from less than ~3m away. Is that causing similar damage, or is laser light different because of it’s coherence?
(which illustrates the difference between diffuse blue sky light and the point source focused on the retina imaging a LED/laser)
laser led eye damage? - Google Search (generally, read a few pages of results)
and do an image search with the above page to see illustrations
and ask your library to get this for you:
http://www.sciencedirect.com/science/article/pii/S0891584915001586
doi:10.1016/j.freeradbiomed.2015.03.034
Abstract from http://www.sciencedirect.com/science/article/pii/S0891584915001586
It depends on the power and color. High power blue may do some eye damage even without ever pointing it at anything reflective or shiny, due to whats called blue-light-hazard. Photo receptors in our eyes don’t undergo their normal recovery process when hit with bright blue light.
And any color can damage your eyes if you hit something reflective, shiny, glossy. Indoors there are lots of shiny surfaces around. Look around, it can be glass, metal, plastic. Doorknob, metal on a lamp, plastic front panel on dvd player, drinking cup, soda bottle, a plastic pen, glossy fedex box, glossy candy wrapper or bag of chips, hell the surface of my furniture is pretty shiny. When you go into higher powers any glossy surface could hurt you if it happens to be at the right angle to reflect right back at you. Outdoors you have retroreflectors used in car tail lights, road markers, streetsigns. Retroreflectors actually are designed to always reflect right back at you regardless of the angle. You might also have them on the back of running sneakers.
Nope. I just wanted something I could start fires with and I got that one…
So I may get the red one sometime just to round out the set…
I ordered the red one. You made me nervous about the blue one as I do not know anything about lasers and have no eye protection either at this time.
The blue one does scare me… It’s so powerful it pops balloons instantly, and can light a match on fire, but is so far in the UV that it’s less visible… A dangerous combination.
What do you think the real power rating of the blue laser might be, over 1,500mW? Funny how they are rated 5mW in order to be legal to ship.
I had a 2,000mW wicked laser and it took a couple seconds to pop black balloons, if this one pops them instantly then we are talking about a serious high power laser.
