Blue model purchased as well: see my impressions in post #11 below:
https://budgetlightforum.com/t/-/33834#comment-778629
I just received a parcel from GearBest, containing, among other things, a new "<5mW" 301-style 18650 Green Laser pointer:
http://www.gearbest.com/led-flashlights/pp_106566.html - $7.22
I was a bit confused at first, initially reporting the laser as DOA, but found that on this device, the cell is inserted with the positive (+) pole to the end cap. After installing the cell correctly, the laser functioned surprisingly well. So far, I've been able to pop a lot of balloons very easily; they will pop INSTANTLY when this laser is pointed at them. I've tried to light matches, but haven't been successful yet. Although the laser is labeled and sold as 5mW, I doubt this.
I also have an old DX <35mW green laser to compare against. The DX laser will pop balloons, but you have to hold the laser steady, and very close to the balloon for several seconds. From two AAA Alkaline cells at 3.05V, I get a tailcap reading of .25A, for a total of ~.75W. This 301 Laser, from a freshly charged 18650, at 4.2V, shows a tailcap current of .34A, for a total of 1.4W. I don't know how efficient these are at input power vs actual output power, but this is roughly twice the wattage of the DX pointer.
The 301 has a proper tailcap lockout key switch, but the keys are very cheaply made; one already had the plastic bow break off; I can fix with super glue, but still...
The battery tube is also separated so it can be used with a single primary CR123A cell, but it would also be a good candidate for use with a 18350 cell, if the extra 30mm is a big deal... In my case, this is a good candidate for my surplus laptop pulls, as the flat top cells work well.
So feel free to post if anyone is aware of any resistor/pot mods that can be made to this unit... I'd like to have something capable of starting a fire, if possible!
<Edit to add further observations>
Okay: So far, I still haven't been able to start a fire. I've been able to get a few wisps of smoke from the tip of a match, but it still won't ignite. Although it seems that heat sinking should be fair, I suspect the unit may be heating up quickly causing power to decline. Outside last night, shooting it against the wall of a shed, I noticed that the spot was very bright, but within a few seconds, would dim to a notably less bright state. I'm afraid to take this unit apart as I don't want to risk damaging it, but I don't see a lot of room for improvement in the heat sinking anyway. Everything appears to be tightly press-fit with metal-to-metal contact.
Popping balloons is easy with opaque balloons; I tried with a more transparent balloon and had trouble getting it to pop...
