If nobody else is able, I might be interested. Maybe a trade? I send you the XP-Ls, and you send me a 219C? (unless there is a US supplier for the Nichia, I couldn’t find one)
I'd have to order some Nichia's again for this, but I'd be alright doing that. But is it not easier ordering the Nichia leds yourself at leds.de? They take Paypal, I just would not know how much the shipping is to the States.
If it’s a hassle or takes awhile to order again I can wait for them to come to mtn or intloutdoor, it’s not a big deal. I was about to place an order with mouser today or tomorrow. Is there a particular variant of the XP-L you would prefer? (feel free to PM me if you want)
My shipment of high-intensity XPLs should arrive Wednesday. I ordered six each of 4000k and 5000k. No idea the tint bin … just the first 4000k and 5000k listed on the Mouser website.
It’s really pretty simple, if the bottome of the TIR in the Carclo lens is more than 1mm above the step on the leg, it’ll fit. Otherwise some modification might be necessary. So be it. I have no problem sawing/slicing/melting/drilling/carving on pretty much anything.
Interesting. The fact that CREE actually sent you a picture shows that they’ve thought about it. This isn’t just some off-the-cuff customer service rep giving a clueless a response.
For what it’s worth here, I simulated these emitters by placing a 1mm sheet of copper over the die and shaving the dome off with a scalpel. 1mm fits under the triple optics. I’ve already assembled 12 of these into the M43 but actually didn’t see the output I expected, probably due to losses by shaving the dome off.
So this will be my second attempt.
But the optics did fit over my shaved emitters.
Edit: I cut a square hole in the sheet of copper that fit over the emitter die.
I have 12 of these in hand as of a few moments ago. Off to the stove top we go!
Not much difference in appearance between these and the ones I cut with a scalpel. I’m not real confident the outcome will be satisfactory, but I will try.
I spashed solder into my eye. But of course I didn’t stop there. I got the 12 XP-L H1 in place and it was acting odd. Holding the button down for Turbo it’d ramp up then shut off. The 35A cells are at 4.15V. I tried again. A double click for Hi and it’s really bright. From there I held the button down and it went to Turbo. Stupid bright! How about 7141 lumens on Hi, 11,902.5 on Turbo, with the cells still at 4.15V.
The M43 Meteor, at 11,900 lumens. OUCH!
High level one does 1735.5 lumens. That Turbo is ridiculous!
Edit: Start up does just over 12,000 lumens. I attempted a 30 second run and at 20 seconds it was getting really hot, making 10,381 lumens. Wow. Ok, I’m impressed!
And for the record, these flat little XP-L H1’s fit under the Carclo 10507 perfectly with this 12 emitter set-up.
