9-9 Updated in OP. 2nd Group Buy of Lumintop SD10 (SD4A)
seems nice, multi-configuration for batteries :davie:
It is aluminium battery holder.(carrier)
Will figure out the moon problem.
I’d like to see this happen. I’ve got the first round Lumintop SD10 BLF-SE, but I might get this one, too.
Well spaced modes including a moonlight mode. NW or HiCRI. A holdster would be nice.
I’m in ! :slight_smile:
WOW!! The BLF II SD10… I’m interested too!
I have one BLF SD10 (“First Edition”)…
P.D.: Please include a holster, I’m using the one of my Nitecore EA4
That sounds fantastic. That's the only reason I sold mine. Output was good, great UI, great led tint, great F&F, but the mode gap at lower voltages on 4aa/D was a huge bummer.
Interested , if it fixes the problems of the 1st version and it incorporates further worthwhile improvements.
Thank you Very Much,
George
How much did the first one sell for ?—Help
I say moonlight… Neutral or warm tint… 4 (or so) well spaced modes… and the ability to run on multiple battery chemistries.
Maybe a XP-L V6 or XM-L2 U4 with 4D, 3D, 3A, 2D, 2A, 1D and 1A tint option even if it cost more?
2nd batch of SD10?
i want one :smiley:
Maybe a 26650 sleeve included for 26650 and C Cell use? If not enough room in the box for another adapter why not have only a 26650 adapter with one of these 18650 to 26650 adapters stuck in it so it will fit in the box?
What does SE mean? Special Edition?
First costed 39$. but this new one might costs a little more. for adding some accessories.
"18650 to 26650" doesn't seem to work in a 32650/D tube. Gap is still there. We provided "18650 to 32650/D" .
Most people have 18650,I think. and it's very simple to use 26650/C. The spring will "lock" the battery, no crack. For safer reason, piece of paper works great.
I know that English isn’t your first language so maybe you weren’t getting my meaning.
I was meaning opening the inside 18650 to 32650 adapter hole to 26650 size so it will take 26650 or C cell (make it a 26650 to 32650 adapter) and use that white plastic 18650 to 26650 adapter inside the 26650 to 32650 adapter when you want to use a 18650.
This way we can be able to use 26650 and C cell batteries too and have room inside the Lumintop box for the AA carrier, adapters and accessories. Putting the 18650 to 26650 adapter inside the 26650 adapter before it’s put inside the Lumintop box so it doesn’t take up as much space.
My “26650 to 32650 adapter” is a pair of o-rings…
But…
That’s a good idea!!!
Ah yes, got u now,sorry.
32650-26650 and 26650-18650.
Just wanted more flexibility to be able to use 26650 and C cell since I consider the Lumintop SD10 the “End of the World/Zombie Holocaust” flashlight. You can scrounge up just about any standard alkaline battery to power it. I even got a 4 AAA carrier around here somewhere that fits inside a 26650 flashlight. Stick that inside a 26650 to 32650 adapter and you are in business.
