Sorry for my bad English if you do not understand
Thatâs right, jumps from 1000 kcds to 1350 Kcds only by the approach, I had taken as a reference the original height
I wonder what would happen if you drilled about 3 holes in the collar, evenly spaced. Then focused three 445nm laser beams of say about 150mw each on the phosphor. Hmmmm
Only one way to find out, itâs a cool idea!
Gotta be careful not to burn the phosphor though!
Anyone who is looking for lenses on the cheap; Ebay has tons of old projector lenses since everyone has switched to digital. There are loads of old Slide projector lenses, cheap for disassembly.
OMG, Gaston! That is simply amazing! I had to read the throw figures 3 times before I was sure I was seeing one MILLION three hundred and fifty THOUSAND candela. Good lord! What a fantastic job! You didnât just build your own Deft X, you smashed it into the ground and doubled itâs throw. Mighty impressive work.
Doubled its throw?? Nice project he did but it did NOT double the throw or CDâS,Not even close to that.
A guy on CPF just sold his certified by Michael @ 1032Kcd=2031m of throw. OPâs claims 1350Kcd=2323m of throw. Impressive although 292m of additional throw is not double! I know Michael tests his lights further than 6m away. We will never know which one throws more because these enthusiasts are worlds apart geographically and follow different standards of measurement.
Hi guys!
I bring some news
I was doing the promised measurements in the place that I could get the results were:
At 6 mts: 1250 kcds
At 10 mts:1280 kcds
At 19 mts 1263 kcds
As you will see, is not that reason, in this place could not reach even 1300 KCDS :~ this is a place that is always closed and could observe many dust particles in the beam in the airâŚThis will be the reason?
After these results to get home I measured again in the same place where I do all my measurements at 6 mts and though the batteries were not freshly charged for all tests in the other place well and everything was still barely above 1300 kcds can influence the environment, in this manner, in the results?
The particles in the atmosphere (cell image)
Zoom in
Zoom out 1.05 meters in diameter to 4 mts
After a late night try taking pictures of the tower at 1600mts, that will light up the water tanks but had the vision obstructed by trees |(
this test had done last winter, now newly started the autumn here, despite this, take my old camera to try to take good pictures to share with you, I hope you like
Look for more distant towers had sight according google earth are to 1.25 Km
3D view:
On the photos to the left will notice a new construction that does not appear on the images of google earth
Control
Zoom
From another angle
Control
Zoom
Some to the sky! :bigsmile:
Nice pics gaston
I so want to play with something like thatâŚâŚâŚfingers crossed it is in my future
A great post. My hat is off to you, sir.
Cool beamshots!
I wouldnât be surprised if a dusty atmosphere has a measurable impact on the figures, otherwise they seem to be relatively consistent.
Another thing that can skew measurements is if there is a surface near the meter that can reflect bounced light from the hotspot back onto the sensor area. For example in a situation where you place the meter in a room corner with white walls either side, Iâve seen increased measurements in that kind of setup as the meter is registering secondary bounce light from the walls.
I wouldnât be too worried about small differences like that, impressive thrower in any case! Well done.
Gaston is real pro in every way. I really like that photos.
great photos!
thanks for sharing
Thanks guys for your comments
Iâm glad you liked it!
Yes LinusHofmann Itâs true what you say, I measure my flashlights in my backyard I place the sensor light meter to about 20 cm from the wall, and in the middle, removed from some corner to avoid what you saysâŚ.
Nice project! Thanks for sharing your knowhow and all cool pics
How could I fake a wavien type collar? Maybe I can butcher an old reflector, flip it upside down and approximate the effectâŚ
Itâs a spherical reflector upside down. Spherical reflectors are very common. Any one of us can produce and sell a spherical reflector without issue. Itâs the end users prerogative if they want to install it upside downâŚ
A curved mirror is a mirror with a curved reflecting surface. The surface may be either convex (bulging outward) or concave (recessed inward). Most curved mirrors have surfaces that are shaped like part of a sphere, but other shapes are sometimes used in optical devices. The most common non-spherical type are parabolic reflectors, found in optical devices such as reflecting telescopes that need to image distant objects, since spherical mirror systems, like spherical lenses, suffer from spherical ...
Resurrecting a zombie thread. Do you think a bicycle
Axle cup or arm cup would be a good candidate for
A waiven collar? It is made of metal so its a plus. Need
Some polishing though.
Excellent build, really awesome.
That is very impressive! I think u should consider building these for ppl ,not for free obviously. Iâm guessing youâll need some finishing touches like waterproofing etc but you are clearly very talented so shouldnât be an issue!
Hi guys!
I bring some news
At 6 mts: 1250 kcds
At 10 mts:1280 kcds
At 19 mts 1263 kcdsAs you will see, is not that reason, in this place could not reach even 1300 KCDS :~ this is a place that is always closed and could observe many dust particles in the beam in the airâŚThis will be the reason?
Hi,
in my opinion these numbers show that you focussed the light to short distance. That´s because the candles are higher measured from 6metres. I think you should try to focus the light to about 200metres and make a new measurement. I think you will have then even more throw.
Awesome build!
Regards
Kenjii
Thanks for the comments
Very nice work.
