Nope it is the HI not HD, they got some "very limited quantity" as they say (XP-L HI V2). In these days such claims are redundant, quickly others will have the same LED for sale, Olight already uses it.
Thanks for correcting me, HikeLite. I too agree there will soon be plenty lights with this new emitter. It is just not soon enough for me.
Is this new XP-L with no dome considered to be an HI or H1? My paperwork on the 12 I got says H1… H One, not H “Eye”
Does anyone know what the proper terminology is? It’s not actually de-domed, but maybe domeless? Flat? Slim? Toned?
Edit: Cree’s Official Word
XLamp XP-L High Intensity
Industry’s First High-Intensity LED
The XLamp® XP-L High-Intensity LED is the first of Cree’s new class of High-Intensity LEDs optimized to deliver maximum candela through secondary optics. The XP-L High-Intensity LED is the first single-die LED to deliver over 100,000 cd in a 4-degree beam with a 50-mm diameter optic at 10 W. Built on Cree’s breakthrough SC5 Technology™ Platform, the XP-L High-Intensity LED delivers more than double the candelas of the industry’s previous highest-performing single-die XP-L LED through the same optic. The new high-intensity LED offers a drop-in ready upgrade for XP-based luminaire designs, enabling manufacturers to achieve higher luminous intensity with minimal redesign to accelerate time to market.
Edit II: They are calling the High Density variant the XP-L HD and this domeless High Intensity variant the HI, for some reason the code reads H1
this is what I bought from Mouser…
Mfr. #: XPLAWT-H1-0000-000BU50E2
Desc.: High Power LEDs - WhiteWhite, 5700K, 70CRI 360lm at 85C
Yeah Cree says “High Intensity” and many of us have been abbreviating it “HI” ourselves. All of the offical product numbers that I have seen have the H in it though.
XP-L High Density (the XP-L that used to be called only XP-L and it has a dome with 4 vertical cuts on the sides)
XP-L High Intensity (the new flat domeless XP-L emitter)
H means High Intensity
If it would be 0 instead of H then it would be High Density
BTW: these are official specifications from the datasheets. Also that code is an "Order Code" and it's for a U5 bin, from the E2 group (3B 3C 3A 3D), it is not an actually "Bin Code" where you know the exact tint.
I’m not flat! Just a late bloomer!
If you must, I’d prefer slim.
Good to know, H1 it is.
Again that H1 is only for the Order Code (which Mouser's special way of not telling you exact what tint you get), what all other sellers will have is a Bin Code not and Order Code, there will be no H1, only a H since that is an internal code.
H = High Intensity, 0 = High Density.
Whats H0 then?
XPLAWT-H0-0000-000BV20E1
Part of Xmas
0H!
Xpl white- high intensity, the 0 is an internal code, as is the 0000-000.
The B is 70 cri Min, V2 is luminous flux group and the last 3 are the chromaticity group
Thanks itsonlyme. Then what does the H before the 0 represent?
What matters is the “H” in “XPLAWT-H”…
XPLAWT-H…. is HI
XPLAWT-0…. is HD
The B is for Bodacious and when you see HS together it’s for HolySh#t!
In other Cree LED’s (don’t remember which data sheet I saw it on) the 0 or 1 in that position means either ‘standard’ or ‘non standard’ order qty. But for all intents and purposes that we should be concerned about, it is meaningless.
How’s your eye Dale? You should wear safety goggles, seriously. I had some solder splashing into my face, that’s when I bought some safety goggles.
Thanks for asking chouster, it’s ok. Hasn’t bothered me at all today so I reckon I got lucky. Beats the heck out of a metal shaving, for sure.
About to head out in a little while and get new beam shots of the M43, with the ND filter turned off. Perhaps a comparative shot from the BTU Shocker with 3 of the 9V MT-G2 emitters? It puts out around 10,000 lumens.
I’ll get all the cells for both charged up so it’s a reliably fair comparison. And yes, I’ll take the lens cover off…
Really looking forward to those beamshots. About that ND-filter, is that something you forgot recently? I guess the cam you’re using has a ND-filter built in…
I’m considering building a X6 3up XP-L HI once they become available over here. Should make a decent beam, right?
Yes, and yes. Last night I shot a sunset with the G1X and was trying some different settings for different effects. I turned on the 3 stop ND filter and forgot to turn it off. So the beam shots I took last night of the Meteor were 3 stops underexposed as compared to my usual settings…the settings were all the same, but the filter effectively put dark sunglasses over the lens.
Yes, these emitters should make a very nice X6 triple or quad. The CUTE-4 optics from Ledil, polished to a clear surface finish, should do exceptional with these in the X6.
