Got one from FP, they claimed it was 3-mode but got a 1-mode.
The lens is smaller than on other zoomable lights so it doesn't focus as well.
These tend to have a problem where the plastic screw-in ring in the tailcap has been shoved in at an angle (not screwed in using the thread!) causing some AA batteries to not fit properly.
Hi there higbvuyb, welcome to BLF! Enjoy your stay here.
I think I can echo your experiences with the SmallSun ZY-C85. I just received one from Everbuying (after not expecting to receive it), but I don't like it at all. It is a single-mode when Everbuying promised me personally that it would be a 3-mode. The beam isn't all that nice compared to my cheap $4.99 eBay No. 5 generic zoomable light, although perhaps better than the Sipik SK-58 beam. And worst of all, the tailcap doesn't screw in all the way with a battery put in. Any way to fix this?
As I mentioned, the plastic retaining ring in the tailcap might not be straight, if you remove it and screw it in properly that should give you a little bit more space for the battery.
I have got two C-85. One from DX and another one from Popbuying. Surprisingly they were absolutely identical, specially by means of output and qualityand sadly, as well for the crucked click switch retaining ring. After rectifying this, they both took a protected 14500 with the endcap screwed in all the way.
I compared them also with the wellknown C78 using a 14500. The output is quite equal, exept the C78 has a more blueish tint. The zoom range is about equal as well, with a slight adwantage for the smaller die image from the C78 when zoomed. Other than that, the C78 is flimsy from A to Z (protruding clicky, wobbly zoom, thin housing) not to metion the ugly and useless sleeve (twisted sewings, no belt loop), that came with that one. Overall I would say the SmallSun clearly is the better buy. I like this one and I will sure buy some more.
Btw: I have got also his bigger brother, the SmallSun C-84 (18650) from PB, for less than 10$! I own also a SmallSun ZY-A4. And yes, I like zooming lights, there are three other models on the way.
