Krono: think you missed my signup for one alu set in post #93
Why not both? You know you want to .
All kidding aside - no way these lights do not make the minimums ,,,, and then some.
Kronos, Dale and JM put a lot of thought into these lights. It would be very difficult to find ways to improve them :) As a matter of fact if one were to buy the internals alone it would be more than the HAIII set......and when you consider the SS/Cu.....well, just try and buy Stainless or Copper hosts for $20 each - just not possible.
I’m thinking that the 14500 light will have to be an “IMR” only light, because of the amp draw.
IMRs come without protection, so Not fat.
The typical protected 14500 will only allow for about half of the draw for the FET driver.
Thanks,
-Chuck
1 SS/Cu set in NW, please.
Great!!
List updated in post 164
Keep em coming ! :)
Sounds awesome!
Count me in for 1 for SS/Cu NW please. Thanks!
Chuck post 169
so the 14500 driver needs low voltage protection ?
The 14500 light will have the same driver as the 18650 light, the LVP will be built in like all of these drivers from Wight and ToyKeeper.
And yes, as an FET direct drive driver it will be highly beneficial to use a non-protected IMR 14500 such as the AW IMR14500 in a red package. To wit, there are no better 14500’s at this time but I could be mistaken (it’s happened before!)
I dunno, because I don’t yet have any, but RMM seems to really like these:
Thanks,
-Chuck
L I B! I actually have some of those! :bigsmile:
Time to do some testing, I’d forgotten all about em… pulled my little Rook just yesterday and topped off the cells and it had these in it. I didn’t even think about it.
I’ll do a couple of checks on a chopped MiniMag triple to see how output is with the AW Red IMR vs. these Windyfires…. be back…
Edit: I also have a SS Maxtoch 14500 light with a 15mm FET driver and XP-L V6 3D, will test that with 3 cells and see how they stack up, should be very relevant to this little proposed copper light. I have an Efest IMR 14500, AW IMR14500, and the Windyfire 14500. They’re all on the charger, same XTAR charger, so we’ll soon see. Will still do the triple for the difference in demand…
My Efest V2 IMR14500 is taking forever to charge, so here’s some results on the AW and Windyfire which will be the top 2 anyway.
MiniMag light chopped by Texas Lumens and built by yours truly, triple XP-G2
AW IMR14500 (Red) 5.59A for 1959.6 lumens
Windyfire IMR14500 5.50A for 1897.5 lumens
Ultrafire C3 SS 14500 light, with XP-L V6 3D and Wights 15mm A17DD S08 FET driver
AW IMR14500 (Red) 4.13A for 1021.2 lumens
Windyfire IMR14500 4.23A for 1048.8 lumens
So, the Windyfire seems to do better in a single emitter FET style light while the AW nudges it out in a Triple set-up. The MiniMag has one of the older FET drivers.
Being as how the Windyfire is easy to get from Richard, I’d say it’s the hands-down choice for this proposed little K6. :bigsmile:
I’d like an aluminum set, NW. Thanks
I want a Al set #42 to match my SS/Cu set, WW, and switch with Nisse, who has expressed interest in #100 if he doesnt mind!
1 x SS/Cu CW, please!
Thanks
- Copper host, 14500 sized, same form factor as X6, but scaled down
(I thought form factor was size so how can it be scaled down?)
(I get it is smaller ie 14500 vs 18650 but is the head the same size or also smaller) sounds like a dumb question but I am unclear about it.
- I want the 14500 in copper NW I am willing to go in and split a set (because I as yet can not buy just the copper :_( ) any intrested parties?
Same form factor here means shape and proportion. The object is to create a miniature X6.
Good luck on that wish, the smaller copper light is going to be in heavy demand! An easily pocketable 1000+ lumen pocket rocket? Yeah, good luck with that.
Krono, one SS/Cu WW & one SS/Cu CW
Current list in post 164...updated to post 183
We are doing great!!!! Keep em coming!
Not a stupid question but just as Dale says.....a scaled down X6 to make a miniature X6 that will easily fit in a pocket,,,,easier than the X6 already is.
Never hurts to ask about splitting but that little piece of copper will be in very heavy demand. That is why the HAIII set is being offered. Either set is deal at the given prices but even so it will not be difficult to sell off any light that one does not want because these lights are limited and serialized. The moral here is that it is worth buying a set whether it is Al or SS/Cu and if you think about it ....two sets
bugsy36, thanks for taking the time to keep the lists going in Kronos absence. I think something has happened with the numbering on your Aluminium list. I was definitely number 31 on Krono's original list, as it matched for both sets. Now it seems to have jumped one spot. Did someone get added in between? Please would you be kind enough to move it back to pos.31 for us.
EDIT: I think it was because malenurse was missed out, so hopefully he will be alright swapping two positions to put nguyen and myself back as Krono did. Is that cool with you malenurse please mate? Would be greatly appreciated, thanks.
Also, djozz was kind enough to agree to swap our positions 13 <--> 15 on the Aluminium set (by PM). I'm just waiting to hear back if mizjif was open to the same for the premium set.
I know it's all very petty this numbering thing - but small things amuse small minds as they say! At least its got us all interacting and talking to each other. Great team building!!
Thanks again,
Hirsh
