Please correct my name on the SS/CU list no. 67 in ' Charga ' ...
Thanks again ;-)
Thanks again ;-)
Thanks so much for confirming on the thread Nguyen. That puts me back to where I was (pos.31 to match the premium set) without needing to disrupt MaleNurse. He did also respond as willing to swap but isn't too bothered about position.
So if you're happy at 32 now and MaleNurse is happy staying at 30 we can just leave it there, else you two could also swap if preferred...
Thanks again to you both for entertaining the ridiculousness!
Keep shining!
If that’s going to happen, and it’s a 14500-size, ya got me now.
Hank - just like the ss/cu set....two lights. One will be an X6 w/ 18650 and the other a scaled down version that uses a 14500 battery :)
How many sir? :) Lol
I PM’d sarge and he agreed to swap positions with me (#20 <-> #57), when/if that is allowed.
Screw it. Put me down for an Al set in WW.
Excited to see the Mini one.
Thanks!
Keith
Put me down for an Al NW set too
Ok, another Al NW set please.
Post #203 not showing on list. Please put me in slot #58. Thanks bugs.
Fellow BLF friends :) .........
For the SS/Cu see these comparisons.
The BLF Ti is the most inexpensive for a custom light and that will still end up costing at least $70. The SS/Cu set is only $80 for TWO working lights that have the A17DD-S08 +1 7135 FET Driver flashed with TK's firmware, XPL emitter of your choosing.
Do I like the X6? I may have mentioned that somewhere :) At these prices AND remembering history....there is no way to go wrong. I would still bet just like the original X6-SE that there will be late-comers or people that just want another AFTER THE DEAL IS OVER. So if you are after just the 14500 you would still be ok. Like the Rey X6-Ti?....well SS can bling just as nice. Point is that we cannot buy just one of the lights offered in the SS/Cu set for $80.
....and yes - I am passionate about this buy (SS/Cu & Al) and I will push for it as hard as I can :) ...and No, I am not on Kronos' payroll....he's too cheap
It’s almost half the price, I’m honestly not surprised, this is BUDGET light forum after all
Bugs, please stop hawking …. I’m at 4 sets already. Might do something nuts like go for 18!
As Budget as I am, that is not the reason for me choosing the AL.
The SS X6 while pretty, will not to be able to get rid of heat like the AL can, and it is Heavy.
The copper K6 sounds cool, but heavier, tarnishes, and HAIII Al is just all this poor boy needs.
Thanks,
-Chuck
Put me down for one set each in NW.
Hey Chuck, with a proper length of paracord through those perfectly sized lanyard holes, the weight of a SS X6 would be quite easy to manage.
Besides, it would assist in ridding heat when you twirl it around …… if you know what I mean.
Added. Thank you!!
You are more than fine Sir (and appreciated too!) :) I was directing more towards those that are not on either list :)
I know The original X6-SE got me that way too. LOL. Aw hell with it!!! I will meet your 4 :)
Hi hear ya, Bugsy.
For those that are not on either of the lists be forewarned, that there will be Weeping and Gnashing of Teeth:-(
These are some Serious lights going for cheap!
Thanks!
-Chuck
interested in $45 set, thanks
So has there been any further talk of the Copper middle on the SS light?
Bugsy36, Please can you correct my item in the Aluminium list is somehow listed as SS/Cu instead of Al. Please also note the confirmation by Nguyen below which should make the position swap (which happened only since MaleNurse was added) an easy one too. Ta buddy!
