XHP50 Convoy M1 Build x2 18650
22 posts / 0 new
Mr. Nobody
Mr. Nobody's picture
the extension tube fits almost perfect. there is a slight expose to the o-ring on the original tube but that is fine and tailcap fits perfect to the tube too.
Xhp50 6200k
Convoy-M1 host with 18650 extension
BLF17FET with standard 5 mode no memory.
Edited by: Mr. Nobody on 08/01/2015 - 16:07
keithd
keithd's picture
Does the XHP50 have the same footprint as the XM-L2? I haven’t had a chance to get a hold of one.
Mr. Nobody
2× 18650 Panasonic NCR18650Bs gives me 4.5amp draw with standard DMM test leads.
will test with shorter leads later tonight.
pics:
djozz
djozz's picture
Last seen: 4 days 15 hours ago
Looks good, no comments, this will work very well Smile
Oh, just one question, will you solder the board to the pill?
Mr. Nobody
I can never get the brass pill to hold solder….. ever. it’s irritating!!! I would much rather the driver be soldered to the pill then with a ring. as for the MCPCB to the brass it already is on the center. I never thought of doing it all the way til it’s over flowing.
freeme
freeme's picture
Last seen: 10 hours 33 min ago
Nice! Where did you get your M1 extension tube?
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Rolz
Last seen: 2 weeks 5 days ago
Nice build and good soldering. It should be a very good performer but the head would heat up very fast on high?
ReManG
The build looks great, but what kept you from running two 18350’s in the stock light. Besides the ridiculously short run time, it would be a neat sleeper….
chops728
Last seen: 18 hours 29 min ago
Try this flux—you’ll be able to solder an ice cube to a brass door knob
http://www.ebay.com/itm/130822032362?_trksid=p2060353.m1438.l2649&ssPage...
Mr. Nobody
Lol I still can. Honestly I like it better without the tube and just two 350s.
itsonlyme
Last seen: 1 year 4 months ago
“Solder an ice cube to a brass door knob” lmao. Brilliant.
Your builds are improving Mr Nobody. Very clean
Jackasper
Very nice build. Super clean… As for the above mentioned flux, I bought a few of them about a month ago and really like the stuff. This guy sells the “no clean” 951 as well as the 186 rosin based flux. Both are Kester.
bibihang
bibihang's picture
Last seen: 3 days 10 min ago
Can I solder on aluminium surface with this flux?
Diode663
Last seen: 5 years 10 months ago
Aluminum requires a different flux and solder alloy.
Gurthang
Last seen: 4 years 1 month ago
Very nice looking build, hope you can post some beamshots soon. Where did you get the extension tube for the M1???
keithd
keithd's picture
RMM
RMM's picture
Last seen: 2 years 7 months ago
I can never get the brass pill to hold solder..... ever. it's irritating!!! I would much rather the driver be soldered to the pill then with a ring. as for the MCPCB to the brass it already is on the center. I never thought of doing it all the way til it's over flowing.
Well, to solder the MCPCB to that pill you've probably got to use a torch or another big heat source because the entire pill, along with the MCPCB, has to be hot enough for the solder to reflow.  It will be fine as long as you've got pressure on the MCPCB while in use.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 min 44 sec ago
Well, to solder the MCPCB to that pill you’ve probably got to use a torch or another big heat source because the entire pill, along with the MCPCB, has to be hot enough for the solder to reflow.  It will be fine as long as you’ve got pressure on the MCPCB while in use.
I use Kester’s solder paste between mcpcb and pill and heat it on the stove, in my $1.50 aluminum fry pan I picked up at a garage sale. Reflow on it also. It’s low cut and small, made of aluminum, it cleans up well too.
KB1428 “Live Life WOT
KawiBoy1428
keithd wrote:
Yep! I believe it’s the same. 5mmx5mm http://budgetlightforum.com/node/36431
cbrake10
I also am curious about the extension tube.
-Clark
D10ten
D10ten's picture
Last seen: 4 hours 41 min ago
I ordered a extension tube ftom fastech. I hope it will fit my old C8 or M1. I was going to use 2 18350 in a M1 for the XHP50, but the batteries was a ltitle too long to fit.
Mr. Nobody
the extension came from fast tech. I don’t remember which one I ordered. this light is now for sale in the for sale section of the forum.
