Ig you are in the Dallas area, you should stop by CDC Surplus in Richardson. They sell lots of quality tooling (a lot comes from local aerospace companies) for very affordable prices. They are closed Sunday and Monday and at at 3:00 on Saturdays. There is also a Harbor Freight a couple of blocks away.
Don’t forget to forgive yourself when you screw up. I usually start with “Oops, $H!T” and then move on to more profound polysyllabic expletives before running down and turning philosophical. In the end you still just have to go on. A cookie helps.
And remember to always leave the key in the chuck before starting the motor (but after writing me into your will) J) Flying chuck keys can be and eye-opening, trouser browning experience.
My friend’s little Harbor Freight lathe deposited his into the sheetrock wall the first time, through the window the second time, and a square ricochet into his nads the third time… some people have a hard time learnin’… A hunk of metal bouncin’ off his dangly bits seems to have improved his lathe hygiene… or he’s too embarrassed to mention any later Flying Chuck Keys of Dooooom… Speaking of which, always wear loose fitting clothing and a necktie before operating a lathe… but after writing me into your will. Somewhere out there is a video of some idiot being decapitated by a spiffy necktie caught in a big mill.
Almost everyone had done or will do this- but not everyone will admit it.
Some guys use one of those brightly colored coiled plastic wrist-band keyrings to hold the chuck key; the far end is tied to something where you have to stretch it to use it. Helps remind you to remove it, is more visible, and for me at least solves the perpetual problem of “Where did I put that $%^& thing?” which in total takes more shop hours than the work does.
Also remember to tighten all chuck holes then go round once more. 3 single jaw tightens does mischief with a 4 jaw chuck, and the habit of going round twice ensures you can never miss a jaw. I learned these things a little too late.
