Maybe get yourself a springloaded key that you can’t leave in the chuck
Not wearing rings prevents your fingers left in the chuck.
I know a guy that built a 5'x10' flatbed cnc router table out of wood and it was accurate as hell too.
Nice work Justin!
You really need to start a whiskey fund. It will help sooth the nerves as you learn what not to do. Above all - HAVE FUN....I admire your abilities!
08/03/15 - Now there's a little more light in the work shop.
The lathe should arrive Thursday before Noon Central time.
Other parts are coming daily. It's getting even more exciting every day.
i hope someone makes a movie of ’lil justin jumping around when the lathe is delivered
That will be his wife jumping around because she will not have to hear Justin complain about finding things to do! LOL
Plus she gets the remote back for the TV :)
Don’t forget the safety glasses in all the excitement
Looking forward to seeing you work your magic with the new machine.
After shirtless pics and somebody wants a picture of “lil Justin” dancing around … did I miss where this thread was renamed?
Fifty Shades of Justin: Rebel with a Lathe
EDIT: wow, and those more recent posts just continue the theme …
Almost everyone had done or will do this- but not everyone will admit it.
Some guys use one of those brightly colored coiled plastic wrist-band keyrings to hold the chuck key; the far end is tied to something where you have to stretch it to use it. Helps remind you to remove it, is more visible, and for me at least solves the perpetual problem of “Where did I put that $%^& thing?” which in total takes more shop hours than the work does.
Also remember to tighten all chuck holes then go round once more. 3 single jaw tightens does mischief with a 4 jaw chuck, and the habit of going round twice ensures you can never miss a jaw. I learned these things a little too late.
Phil
How is it getting from the pallet up onto the bench?
Looking great OL! Congreats! Thanks for taking us along for the ride.
Good observation Scott, by having the bench in place (with shelves and stuff at the end and boxes for tools attached) it will make it very difficult to lift several hundred pounds of lathe into position. Limit’s it to 2 people, and the boxes on the end of the bench will compromise that persons position. (similarly, any hooks or nails on the other end may well gouge someone)
Not trying to be critical, just making an observation based on years and years of carrying heavy items.
Don’t know yet. Haven’t figured it out. Progably will have to rent an engine puller and have a guy drop it off. Don’t want to use people. People can drop things and Murphy is usually on the heavy end.
Unfortunately, there is only one place the bench can be and it’s a bad place, because the area is narrow and it is higher than the “floor”, because the area for cars is slanted at an angle and the only areas that are flat, are on the edges. The only other way would be to have the bench out, load the lathe and then pick it all up and that would be over 500# and still no more than 2 people, because it still has to go against the wall. No good solution has come up yet.
I have a chain hoist bolted on my ceiling to lift stuff between 150-800lbs. It was cheap and has been useful on multiple occasions. If you have it mounted on a bar you can get some side to side shift out of it.
Like this
Nice rig
I have something similar but not as nice.
Is that knot in the wood going to weaken that beam?
Does anybody have any recommendations for parting tools? They would be handy for cutting off pieces, and maybe cutting cooling fins.
Was thinking of something like This to lift the pallet or lift the lathe from the pallet to bench height. I’ve used other types to lift garage door and deck beams weighing 60lbs a running foot into place. They make midget ones for lifting wall cabinets as well. I’ll be using both large and small hoists in the next month and swear by them. Rental companies let them by the 1/2day, 3 day, week. Have some 4’ 4x4’s on hand to set the pallet on at deliver so the jack wheels can slip under the pallet.
Possibly a bit, but it’s not actually mounted at that spot anymore, so a bit of a moot point. What may be hard to see is just how close to the end of the boards it’s mounted. In the spot in the picture it has lifted my lathe, manual mill, and 60 gallon compressor without issue.
