It’s a Nikon SB-400 blitz for my D80 and D3100 SLR.
Ok, on remote control. But it don’t hurt to use normal eneloops on a remote control?
Was thinking maybe 3 x eneloop 2100mAh+ was lasting longer then 1 x 18650 3200mAh? But of course, the eneloops has only 1.2v, but the 18650 has 3.7/4.2
I have been at the store to look before I posted here, but some days ago I found a store/seller with better prices, but I can’t find it again.
No, it wont hurt to use standard eneloops in remote controls. but if Lites are cheaper, I would go with the Lites.
I honestly dont really care which brand/batteries I use in remote controls that I use daily.
I have eneloops in my remote shutter for my camera, but thats the only "remote" I use eneloops in. The remote controllers I use daily probably have alkaleaks in them.
Its the ones that get stored away, that I prefer to use proper batteries.
No, 3 times 2000mAh in series is still 2000mAh. The voltage becomes 3x, (about 4.2-4.5V)but not the capacity. (someone else will be better in explaining this, but you can search for Series vs Parallel batteries for more info)
Depending on the use of your strobe. if you need the capacity (shooting weddings etc) you should go with teh Pro.
If you "just shoot" with strobes occasionally, the standard eneloops will do just fine!
When charging Eneloops (or IKEA Ladda) AA and AAA batteries. Is it best to use the lowest setting, 300mAh, or can I charge them with higher current then that?
Got the test results now, Ikea Ladda AA 2000mAh gives from 2200-2270mAh and the AAA 750mAh gives from 770-801mAh. So seems like a good battery, like you say in your test. And they are cheap, just $4.6 for 4pcs of either AA or AAA.
Sorry for that I ordered Eneloop Pro batteries also from Ebay, they was expensive, and in terms of mAh not much higher.
But Ikea do not give any info about how long the charge hold on the batteries, like Eneloops, but most likely, 70%+ after a year.
Thanks for the tip, I just paid a little too much to buy two of the AA at Ebay after reading your post, but I wanted them for a nice solar light that I have. Now that I have those two, I will now shop for a few more, at better prices.
My understanding is that they are the ultimate battery for those AA solar yard lights.
Just finished charging my disney eneloops and after 20 and something circles the still rock so thought to say thank Chibim for supplying them, it is really pity you are not in Tokyo anymore so I could get another 8-pack
