Quickly, grab a dozen (or two) 8-packs, PRO preferably :bigsmile:
If I grab them they might end up in my suitcase instead of an envelope.
That’s ok, you can send them later, when you unpack your things
It's too bad you're moving back... there's too many great things about living in Japan, but there's also many bad things too lol
Today I charged 4 IKEA Ladda AA batteries (they are Eneloop? Since they are on the HKJ chart? Three charged fine on my Opus BT-C3100 v2.2 charger, and they stopped charging after a short time, since they are charged ready. But one battery was still taken @1A, and had charged over 1200mAh, and it was really hot.
Should I assume that battery is damaged, and just recycle it? Not take the risk? They are really cheap, $1.2/pcs when you buy them direct at IKEA here in Norway, and I got a bunch of them, since they had really good test results. So risk anything, doing more testing? or recycle?
@myhken, probably better open another topic..those Ikea are not eneloops, and definitely not Japanese eneloops.
I've basically stopped buying other batteries than eneloop for that exact reason for my flashlights.. Eneloops have (very close to) 100% satisfied users history. Yes, some other brands are okay, or even good, but nothing that comes close to eneloops 10 year history. They don't have that track record.
Put your mind to ease and go 100% eneloop.. stop being worried, and you don't need to keep testing cheap batteries to see if their cost ratio is better, because that takes a lot of time. Unless that's just something your really enjoy doing, or for sharing with others.
It really is a small extra investment, which makes your life much easier gives you more time, and don't worry about self discharge. Unless you have tens of flashlights that take AA or AAA batteries.
(Not talking about other applications)
Amen
I've pretty much decided to do the same too... there's many brands out there that might be cheaper, but it's not worth it in the end due to poor performance
I noticed Costco got the made in Japan Eneloops back in for $21.99 for a 10 AA's, 4 AAA's, and a charger. I'm going a pickup another pack the next time I go next week
I was recommended Ikea “Ladda” batteries in this thread, so it was not just about the price, but because the recommendation here, and on HKJ website. And seeing realtime test results here at home, they have their specs and more. (average 2100mAh+)
But I had allready ordered Eneloop Pro AA and AAA, and normal Eneloops, and the tropical Eneloops from different sellers on Ebay. Got my first batch of Eneloop Pro AAA yesterday, tested all 8, and got results from 917 to 979mAh on @0.5A. They was from July 2014, made in Japan. (ordered from Japan). Waiting for the 8 x AA Pro and 8 x normal AAA (4.gen) to come from the same seller. Think they will be good also.
Then I have a order for two 8 x Eneloop Pro AA batteries, also from Japan (location in Japan). Hope they checks out also.
Last order is from a UK seller with around 330.000 sales, and 99.7% happy customers. Thats the tropical color AA Eneloops batteries.
My plan is to use IKEA Ladda in “not so important stuff”, and Eneloop Pro there I think it’s the best, or normal Eneloops there they fit best. (remote controls etc).
I use quite a few AA and AAA batteries in a year, always have a drawer full of normal AA and AAA batteries. Now I can change to rechargeable batteries on all stuff there I use AA and AAA batteries, and will save money and the environment over time.
Have checked all my Eneloops I have got to now (8x AAA Pro and 4 x AAA normal, both 4.gen) for all the signs of real or fake. And they are all real. They have a matching date code “in graved” in each battery, matching the date on the package. All the looks is right. The mAh match when tested. So buying directly from Japan was a good idea. Of course, the price was not in lower segment, but OK.
I stick to Eneloop now that extended lifecycle testing has shown them to outlast others. I once had some Panasonic 2600mAh cells. After a year they were down to 1800mAh. 50-100 one hour long runs down to empty had done them in. Max on a bright torch destroys lesser cells, Eneloop seem to survive.
Go with Eneloops or go home!
Got a package with Eneloop AA Tropical colors today, from a Ebay seller with 330.000 sales and 99.7% happy customers.
It says on the package and on the batteries that they are made in Japan. The date on the package is 07.2014, but they are marked BK-3MCCE/8PE and not BK-3MCCE/8PT, and BK-3MCCE/8PT was produced in December 2014, so it could not been from July 2014?
And there is no date code on the batteries. Testing the capacity now , but without the date code, is this fake batteries?
Edit: Found the date code on the batteries. 14 07 TE (or TF). So same as the on the package. Maybe this is the real deal?
And if yes, safe to use, or just ask for a refund and recycle batteries?
They had a charge of 1.30V+ when I put them on the charger. The BT-C3100 charge them up to 1.50V, and then start to discharge them.
The package looks like this one:
Edit: All batteries has their rated capacity, between 1910 - 2000mAh.
So the last question, did they make BK-3MCCE/8PE in July 2014 with tropical colors?
1. The production date is usually earlier than the actual date they come to the market. So that doesnt have to be an indication that they are fake.
2. Eneloops are known for consistent capacity numbers between every new set of cells, so if they are quite close together, that might be an indication that they are the real deal.
Im glad you did some testing.
3. Unfortunately eneloop has been a little "crappy" with coding eneloops.. But after some research it looks like the BK-3MCCE/8PE are provided for the Polish/Hungarian/Slovakian region.
Conclusion: I am pretty sure they are real.
I am still thinking about redoing the first few posts of this thread with some updates on the different (new) codes. They don`t always make sense..
(just found a website talking about fake 4th gen eneloops, but can`t say if they are correct, because there havent been any testing on the actual cells, only packaging) http://quatangso.net/pin-sac-eneloop-1-1-1257205.html
Thank you.
Has anyone seen the new eneloops that claim to hold a charge now for up to 10 years? I just got some, but not tested them yet.
Some new eneloops
for the European market, August 2015 (not available in Japan)
Eneloop Organic
August 2015
and some made in China
Eneloop Hello Kitty
bk-3MCCB 2KC
Made in china. Ouch!!
Avoid them… (IMO)
Glad we see new special edition…. But… There was a fifth generation ready for production???
